Question about Catnapper Champion Power Lift Lounger Recliner in Blue
How do I disassemble a catnapper recliner for moving into room through a 30 inch door?
Everything but disassembly
The vacuum handle won't recline. Everything else works great, how do I fix it?
It sounds as though either the pushbutton may be broke or out of alignment. The recline works by pushing the latch pawl out of the locked position to allow the handle to recline. I have the user manual link and while it does not have that particular maintenance item the beater bar disassembly should let you see the mechanism to see if it is broken.
http://www.eureka.com/FileLibrary/e3d6977195674480857fbdfd0948b1a6/en_88151_OwnersManual.pdf
Oct 16, 2015 | Eureka AS2030A - Airspeed ONE PET Bagless...
I would like to have my Osim 7800 in my upsstairs bedroom, but it wont fit up the stairwell or in the door. Is there any way to safely disassemble the chair to move it and then put it together again?
If you can lock it down in the fully reclined position (may need to use a few plastic zip ties, strung together, or some bungee cords) it flattens out quite a bit. Two or three helpers should then be able to get it in the room perhaps by standing it up and turning into into the room rather then trying to carry it in. It may also help to rmove any doors in the way as well.
Oct 29, 2014 | Furniture
Can I disassemble the loveseat to make it fit through the door.
I think you can disassemble tis, but you never will be able to put it together again. Ask some strong guys to help you to bring it in the room you want it. Sometimes it only needs to be put on its side and make a turn. use some cloth to shield the exterior. Must fit to almost all normal doors.
Jun 10, 2014 | Ashley M Ashley Furniture Wesley - Sienna...
Why does only part of my control for catnapper power lift chair work
The plug can be disconnected from the box. There is a box that connects the motor, the remote and the lift. Make sure all connections are together..
May 19, 2014 | Home Meridian Comfort Lift Recliner
I need to move my body solid G4I to another room,
first disassemble the chest press then tie wrap the cable to frame. pull the weight stack off then tie wrap weight stack cable then remove rear base all away to where the front seat is attached now you should be maneuver to the other room
May 13, 2010 | Body Solid G4I Iso-Flex Home Gym
Can I disassemble my Sony KP-57w-s500 to move from one room to another? It is too big in one piece. Can I separate the top from the bottom?
The only TV's I worked on that the upper and lower halves would seperate was a Hitachi 65 inch projection. So to sum up the answer, no you can not seperate this set.
Nov 03, 2009 | Televison & Video
Catnapper Champion Power Lift Lounger Recliner in Blue Logo
485 people viewed this question
Top Catnapper Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Catnapper Furniture Expert? Answer questions, earn points and help others
