Question about Ipcw 2000 Chevy Camaro - All Camaro models - Headlights
No headlights on 2000 chevy camaro. Where can I find the fuses
    Scholar:
  • 103 Answers
Under the hood mounted inside the engine compartment. Lift the hood, it (they) will be on the right side. Fuse panel cover should indicate which fuse is for what.
Posted on Dec 10, 2014
I have no low beam headlights or foglights on my 1994 chevy camaro
Your headlight switch may be bad. You may also have a short in your wiring somewhere associated with the fog lights.
Feb 18, 2013 | 1996 Chevrolet Camaro
Where is my headlight relay switch at on a 1994 chevy camaro
Relay switches are typically under the hood on drivers side fuse panel or possibly in fuse panel under dash on drivers side.
Jan 21, 2013 | Cars & Trucks
Lights on 1998 chevy camaro wont turn on
check the fuse both high and low have fuses
Sep 19, 2012 | 1998 Chevrolet Camaro
Where is the relay box in the 85 chevy camaro for the fuses...not the fuse box tho...also I just put new head lights in and they don't work now what could be the problem....they arn't broke
There is no relay box in a 1985 Camaro. There is a circuit braker built into your headlight switch and a separate one in the fuse box for power accessories. There are fusible links in the engine compartment but none are related to headlights. There is one by the starter solenoid and three up by the junction block on the firewall. One is for the block itself and one for the alternator and oone for the ammeter.
I would try replacing the plug-ins for the headlights first. Those will go bad although you can usually wiggle them around and get the lights to at least flicker. If not them then the headlight switch itself is likely bad. Hope this helps.
Aug 22, 2011 | 1985 Chevrolet Camaro
Where is the fuses box for a 94 chevy camaro
one on side of dashboard on driver's side n another under the hood on drivers side, rectangle shaped black box.
Sep 19, 2010 | 1994 Chevrolet Camaro
I can't find the fuse for the headlights on a 1991 chevy camaro RS
its under the hood on drivers side toward the firewall or possibly under the dash on the drivers side
Sep 12, 2010 | 1991 Chevrolet Camaro
Headlights do not work on 96 camaro.
by looking at the manual for my 97 Camaro and if you say that the switch is good then that helps narrow it down a lot, because i found a circuit breaker... not a fuse!...located inside the headlamp switch itself. good luck and let me know if you find it... c.b's. are usually resetable please let me know if you fix it because i have the same car and it might go out on me someday..thanks man! also you can see if your getting voltage on the yellow wire when the switch is in the "head" position..if its not there, then its almost a guaranty that its the c.b.
Apr 26, 2010 | 1998 Chevrolet Camaro
Burnt plastic smell that burns your nose
sounds like it could be electrical then... have you done any changes to the electrical at all? rewiring, changing headlights, etc? I had a similar smell when I changed my headlights... new headlights were defective and were melting the housing and harness...
Aug 11, 2009 | 1994 Chevrolet Camaro
How do i change headlights for 1997 chevy camaro
There is a retaining ring or frame around headlight, remove the three screws and the ring will come off, then headlight will slide out the front. Just unplug connector and reverse process to put it back in. Added note at first glance at screws you will think I can't get there from here, but you can lol.
Aug 06, 2009 | 1997 Chevrolet Camaro
Ipcw 2000 Chevy Camaro - All Camaro models - Headlights Logo
113 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Bill Boyd
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
