Question about LG LSC26905TT Side by Side Refrigerator
My water tank in the back of the drawer is empty. I removed the filter and pressed the water lever in the door and water comes out from where the filter was. I replaced with cap that came with the side by side and still nothing. I replaced the filter and still nothing . What might the problem be?
    Novelist:
  • 150 Answers
The filter head sounds like it may be defective, the bypass plug allows the water to pass through the filter head to the tank and on to the fountain. You can also try a new filter as the filters can be defective too. Pleazer Appliance....
Posted on Jan 17, 2015
3 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: LG LRSC21934 side by side. Noticed lots of water
Make sure your door fits good and flat. I run a piece of paper all around it to check the seal. Close the door on the piece of paper and try to slide it. Check all around.
Posted on Apr 25, 2009
erpaalai
  • 999 Answers
SOURCE: Water dispenser in door stopped working. Replaced
Check the reservoir behind the crispers. I could be froze especially if the frig was extra col recently.
Eric
Posted on Jul 16, 2009
I have a water tank behind the top drawer of my LG. Itseems to be empty I have checked the supply to the fridge and it is fine. I removed the filter and pressed the lever, water comes out. put filter
Sounds like a problem with filter. Was it having problems before installing new filter. Filter may be in backwards. I recommend reinstalling the filter
Dec 10, 2014 | Refrigerators
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    The ice is working fine. However, the water will not flow. Water was working fine. I was out of town for about 4 weeks and the filter light was on when I returned. I changed the filter and now water...
    Remove the drawer containing the Ice cubes , and blow a hair on the pipe where the water come in. If it wasn't used for 4 weeks perhaps the nozzle in the inlet pipe froze. Then put the empty drawer back in so the ice maker thinks it needs to make ice and see if it will work
    Hope this helps
    Loringh
    Nov 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
    We have an indesit is70cs. The empty water light will not go out (even though the water drawer is empty). So this means we are not getting any heat to the washing. We have cleaned out the filter and...
    empty light is operated by a microswitch in the box where the pump is and fault can be:
    pump faulty
    microswitch stuck in up position.
    to access, remove small panel on rhs at back and box will come into view
    Aug 31, 2008 | Dryers
    Frozen Water in Pan behind freezer drawer.
    yes you will have to remove the freezer door and go through the front of the unit. the door itself is the easy part to get off, it lifts off the rails, you may have to remove a screw a few inches back fromm the freezer door on both freezer rails(phillips head screw, ). empty the freezer pullout before trying to remove. after that the the pull out upper shelf comes and thenyou can remove the horizontal rails , the ice maker drops down and then the back wall can be removed
    Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
    No water from dispenser
    I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
    more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
    Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
    Slow water flow
    dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
    Mar 20, 2007 | Frigidaire FRT15G4B Top Freezer...
    Fabric Softner drawer
    The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water enterence and distribution to drawer's cells (following the programmed cycle)are done by a lever's movment (part of the dispenser). The lever movment is controlled by two solenoids that received their power from the timer. By openning upper machine's cover you will have an access to the dispenser. Dissconect the power cable from the machine before moving to next tests !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movment). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
    May 31, 2006 | Hotpoint WMA31 Front Load Washer
    LG LSC26905TT Side by Side Refrigerator Logo
    79 people viewed this question
    Top LG Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    christian nielsen
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
