Question about Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White
My Elba washing machine, about every four loads, will fill with water and start beeping instead of agitating. No matter what I try... turning it off, starting it over, moving the sopping wet clothes a
Everything I can think of :)
  • Angie jaten
    Angie jaten Dec 10, 2014
    It looks like my question was cut off. I've tried moving the wet clothes around as wel. When it starts again, it fills with water and beeps again once again without agitating.
    Master:
  • 706 Answers
Sounds like a bad circuit. This is a complex repair, I suggest calling a appliance repair service
Posted on Dec 10, 2014
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Beginning of wash cycle starts agitating instead of filling w/water.
the water pressure/level switch contacts are welded together,usually the load selector switch for the amount of water lets it fill to a determined water level and the water level creates pressure in a tube from the tub to this switch and stops water fill and starts the wash agitation cycle,replace this switch inside the control panel
Mar 19, 2011 | Whirlpool Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Will not agitate after water fill up. Motor makes whining sound.
It sounds like it could be the coupling that has worn or broke, to verify this put the washer in spin, let it drain the water out (if it will) then turn off the timer or open the lid, wait 10 seconds or so then start back up in spin. If the washer just whines then it is most likely the coupling. I have put together some instructions on this if you follow this link it will tell you more about it and how to replace it if you wish. Let me know if this helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
May 06, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Series 70 washing machine Will not fill with water
Sounds like your pressure switch behind the control panel is stuck. Try unhooking the tube going to the switch and see if it breaks free. If not replace the switch.
Nov 19, 2008 | Kenmore 24032\24036 Top Load Washer
Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White Logo
218 people viewed this question
Top Fisher Paykel Washing Machines Experts
marlin siecinski
Greg Stephen
Greg Stephen
Paul P
Are you a Fisher Paykel Washing Machine Expert? Answer questions, earn points and help others
