Question about Singer Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
Changed bobbins, changed needle, changed thread,checked machine & bobbin thread are threaded correctly, made sure bobbin area was clean & dust free, checked tension & stitch length on upper thread.
  • Singer Master
  • 1,860 Answers
Try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Posted on Dec 10, 2014
  • 29 Answers
SOURCE: a horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Posted on Jul 14, 2007
SOURCE: Singer 2010
If model 2010, the problem is a part metal- part plastic part attached to the bottom of the bobbin winding lever, the white tear-shaped thing with the arrow on it. If that will turn past the center of the bobbin it's broken inside. to try a do-it-yourself fix, turn upside down, remove 4 screws, including one by the plug (which must be pulled out for safety anyway) remove bottom case. looking at left end of the works, move the bobbin lever and you'll see the broken part move. The plastic part should be broken about half-way down. You can see how the part should push the white plastic bobbin winding shaft up and down when lever moved. the part can be removed by loosening the 2 tiny hexnuts holding it on the metal shaft. you'll need the smallest size allen (hex) wrench there is. NOTE where the part is at bottom of the metal shaft for when you put have to put it back on. be careful to hold the bobbin winding shaft itself in place, but it's easy to see how it goes back in if it pops out. if the break is clean (like my wife's that I just fixed this way yesterday!) you can put a drop or 2 of good crazy glue in the break, making sure lined up on the sides, then clamp in a vise (or hold firmly together with pliers) for at least 10 mins, longer better. wait at least an hour before putting back. putting back on is a little tricky but you move the bobbin lever to left (open) position, make sure it's just on the end of the shaft (shaft barely protruding) and see where the part isn't pushing the bobbin winding shaft. re-tighten with hex wrench then see if the repaired part now pushes the bobbin winding shaft up and down when you move the lever back and forth. Turn back over and move the lever without a bobbin spool- you should see shaft move up in the middle of bobbin case where it will engage the bottom of the bobbin spool where the x is.
Now if part can't be fixed it is available from auth Singer service center in you state but runs $40 or so. they'll try to tell you they have to install it because of special anti-static gloves that wont fry your motherboard on the machine's computer, but the center in Michigan finally said they would mail it to me. hope this helps! funny I just saw this after fixing our machine which hadn't been used for a long time until I decided I might as well look inside if I was going to have to buy her a new machine!!!
Posted on Nov 24, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
SOURCE: my singer athena 2000 won't
Yes, the hook timing is off. You need to either take it to a service repair center, or do the timing yourself. If you're mechanically inclined, go to youtube and look for a video by Nilsandkatrina about how to repair your sewing machine. He gives a very good example.
Posted on Nov 29, 2011
Bobbin case
Suggest you search in utube videos which be much easier for you to watch and understand.
Oct 30, 2013 | Singer facilita 9858 Mechanical Sewing...
My thread is getting caught under the plate by the bobbin casing when I'm trying to make a buttonhole. Also my fabric is a little thick and my feed dogs will not pull the fabric through, so then I have a...
If you have an a self wind bobbin make sure the bobbin winder is all the way down and no thread caught under it, your machine should be able to cope with thick fabric, slacken the pressure on the presser foot
Oct 03, 2013 | Singer Touch Sew 7462 Mechanical Sewing...
Singer 2263 will not sew because bobbin thread winds back around the bobbin
have you tried changing the needle?
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is inserted correctly into the bobbin case & also wound correctly
May 14, 2012 | Singer 2263 Mechanical Sewing Machine
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
Bobbin
To insert a filled bobbin, lift the presser foot and turn the hand wheel to put the needle at the highest point. Slide open the face plate and drop in the bobbin with the two holes up. Pull the thread into the groove near the center front of the bobbin opening and then to the left (another groove). Then pull it to the back of the machine and close the face plate.
To wind a bobbin, you will need to unthread the machine most of the way. Leave the the thread through first and second thread guides. Then bring the thread around the bobbin winding disc (so that it goes under and around the disc) back towards the bobbin pin (on the top right of the machine). Pull the thread through the correct hole in the bobbin (the one away from the center of the bobbin). Leave a 4" tail. Push the bobbin onto the pin and then push the bobbin and pin as far to the right as it will go. Hold onto the thread tail and step on the presser foot to start winding. After ~10 winds, temporarily stop winding and cut the thread tail. Then step on the presser foot and complete winding. When done, cut the thread to separate the bobbin from the top thread. Rethread the top thread and insert your bobbin.
The manual for the 4228 is available here: http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf . See page 31 (18 of the pdf) for pictures of threading and winding the bobbin.
I hope this helps.
Jan 19, 2012 | Singer Inspiration 4228 Mechanical Sewing...
MY TOP THREAD KEPT BREAKING AND NOW IT WONT PICK UP MY BOBBIN THREAD. I REPLACED THE BOBBIN AND PUT IN A NEW NEEDLE AND IT STILL WONT WORK.
try rethreading the top thread
and check the tension try 3-5
sometimes the needle & thread are not compatable-try this & see if it helps
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 25, 2010 | Singer facilita 9858 Mechanical Sewing...
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
I have a Singer mod 9134 sewing machine. It keeps
Try inserting the bobbin in the reverse direction. Most machines take a bobbin clockwise or counterclockwise and it can make a difference. Also try a new needle, a bad needle is often the problem believe it or not.
Nov 10, 2009 | Sewing Machines
A horrible tangle
Jan 05, 2007 | Singer 2662
Sewing Machines Logo
110 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
