Question about Kenmore Kitchen Ranges
How do I fix error code F23 on Kenmore oven
Changed control board part number 316519204 because it had burned area and convection fans ran constantly
    Master:
  • 346 Answers
Googled error code F32 Kenmore oven and got this: Sears Parts Direct.com. Quote: "The F23 error indicates a communication fault between the main electronic control and the variable speed convection board.
Most likely the variable speed control board will have to be replaced.
I recommend a technician check and repair this problem." Hope this is your oven. You can also download an installation guide and owners manual here.
Posted on Jan 03, 2015
fridgetech
  • 473 Answers
SOURCE: MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Posted on Dec 04, 2007
jsrock516
  • 5911 Answers
SOURCE: GE Wall Oven - error code F1
According to GE, the F1 fault code indicates a problem with the Electronic Range Control (ERC) Board. If the fault cannot be cleared, they recommend replacing the ERC and the touchpad. Has your repair guy tried any of these ideas? Post back with your comments, please.
Posted on Jan 17, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
SOURCE: F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Posted on Oct 14, 2008
  • 4 Answers
SOURCE: Kenmore Oven Door Lock Stuck Out
We had this same problem. We found that pushing the censor button/switch on the upper left rim of the oven's inside moved the lock and made it capable to unlock, or purchase a pizza pizzaz.
Posted on May 25, 2009
What is error code E035 on a Kenmore electric range w/ an invection top and a convection oven
Kenmore 790 Model Induction Cooktop Error Codes Sears PartsDirect
Take a look at this link ... for model 790 it indicates that error 35 is:
Improper power supply voltage (low voltage) or failed wiring connections
Check:
Disconnect power. Check the power supply wiring. Have an electrician check the supply voltage. If the connections are good and the voltage is normal, the main power control board or filter control board is defective.
So it may need a new control board...
Mar 14, 2018 | Kenmore Kitchen Ranges
Error 40 on kenmore convection oven
The 40 error code indicates a failure of the cooktop lockout board. The cooktop lockout board is not communicating with the main EOC electronic oven control. This could be a loose wiring harness or either the EOC board or cooktop lockout board is faulty. This type of diagnosis will require using a volt/ohm meter. If you decide to check the harness to the boards you will need to remove the back panel for access.
Oct 15, 2017 | Kenmore Ovens
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
Sears Kenmore 790 9505 oven the convection fan is always on while using the oven. No matter what setting. Is this normal?
This is not normal. If the wiring is intact, the problem may be due to a stuck relay on the control board. We can rebuild your control board. See here for contact details:
Fix your board Repair control boards for home appliances
Sep 07, 2015 | Kenmore Ovens
Errorcode f23? WHAT IS WRONG.
The F-code usually relate to the gate closing or locking.
[PDF]SERVICE DATA SHEET 318127067 (1010) Rev. C
ftp://ftp.electrolux-na.com/prodinfo_pdf/lassomption/318127067.pdf
1) if the oven controller displays an F15 error code and the ESEC controller ... F23 The controller failed to communicate with the convection fan and oven lights
Aug 17, 2015 | Ovens
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
We cleaned my kenmore elite oven. now it won't work. when i try and turn it on i get an F23 error. do you know how to get the oven/stove working again?
Error code F 23 indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
  • The error code F23 can often be resolved by removing power to the appliance for a minute and then restoring the power.
  • By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
  1. Unplug the unit or turn the circuit breaker off for 60 seconds.
  2. Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
  3. Check to see if the error code is still displayed on the range.
  4. Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed. The unit should be inspected by a qualified appliance repair technician.
Should you choose to use Sears, the number to schedule a repair tech is: Sears Repair Department 1-800-469-4663.
Nov 23, 2010 | Kenmore Ovens
Kenmore Elite micro/convect model 64289. Convect not heating...F1 error
F 11 code. it is a touch pad error.
if you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 18, 2010 | Kenmore 63672 Convection/Microwave Oven
Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Feb 07, 2010 | Kenmore Ovens
Kitchen Ranges Logo
371 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
