How do i know to on TCL21m62s using remote they did not on the TV maybe the remote is already new battery but the TV is on red light already but they did not display or ON?
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician. The main board to your TV should be checked.
Posted on Dec 10, 2014
5 Suggested Answers
SOURCE: Remote control of VX32L HDTV10A
Could be a bad remote. Could be the IR sensor in the tv. If you don't have a another remote you can purchase one for less than 15.00 on ebay.
Steve
Posted on Aug 13, 2008
  • 73 Answers
SOURCE: The remote control will no longer work even when I put new batter
Sometimes the IR receiver bug in the tv goes out.
To clarify. The remote RM1 for TV 1 will not work on TV1, but the remote RM1 works on TV2.
If this is the case, answer is above.
Best Regards,
Charles
Posted on Jan 09, 2009
  • 89 Answers
SOURCE: Remote Contol will not work, though batteries are new and red light is blinking
if it is a universal remote just look up your t.v. in the instuction book that came with the remote,and follow the instructions in the book on how to put in the code for your t.v.
Posted on Jun 03, 2009
  • 736 Answers
SOURCE: Remote not turning the Zenith Plasma Display Panel TV on/off.
the remotes are usually multi function .. that is, they can control more than just the TV .. make sure TV mode is selected ... if its in VCR mode or Cable or whatever then it wont control the TV .. if its a programmable remote then it may have lost its program and would have to be set up again ... if its the original that came with the tv then that shouldnt happen . once in a while but not often i see a bad LED (at the tip of the remote) ... those are infra red so you cant see the light beam but a digital camera can .. point the remote at the digital camera and you should see the LED flashing in the cameras viewer when a button on the remote is pushed ...
Posted on Nov 05, 2009
Palsonic 32" model TFTV326FHD, remote sensor light just keeps flashing red when you try to turn on TV with remote. We tried new batteries, unplugging TV, other connections fine, but TV wont switch on.
The "remote sensor light" is the power indicator and it is blinking to let you know either an internal fuse is open or the power supply has failed.
Jan 16, 2018 | Televison & Video
I need to know if the remote is defective or if it is the TV.
early remotes work by infra red light ( small bulb or opening at the front of the remote )
turn on the camera of your cell phone -ipad and aim the remote at the camera lens
if you see a white spot on the screen when you press the remote button , it is working
Nov 28, 2015 | Televison & Video
Bush tv red light on tv but want respond to remote
Your question is difficult to understand. Did you check to see if your remote batteries are dead or dying? Move the remote closer to the TV and see if that helps, maybe you have the remote backwards in your hand.
Dec 21, 2014 | Televison & Video
My TV is not turning on. It was working last night when I turned it off. The red light is on and the cable clicker's lights turn on so not batteries. I pushed the on button on the top and still not
Hi Katherin,
Place your remote towards the camera. (The IR emitter -small light bulb sort of thing should be placed frontwards.) press any button and look through the camera, you should see a white light when you press the button.)
This is the only way to check Infra red light because our naked eye is not sensitive to check it. (use your phone\'s camera)
if the light is not working. check the remote. Maybe wrong installation of batteries or they are dead OR need a new remote.
if the light is working,need more attention then. (sorry can\'t call you i\'m a sri lankan. Can viber you although. ) if the problem presists let me know i\'ll viber you :)
Oct 11, 2014 | Televison & Video
Mitsubishi tv remote will not turn tv on. put in new batteries already . only the red light on the tv button turns on.
You should reprogram your remote. Start with the tv on. You have got to find a code that will operate all of the functions you want it to. In others some code will only turn on the tv. Some codes will work with volume and the channels. Once you find a code that works you should be able to operate the tv with the remote. It sounds like to me when you put new batteries you erased the function of your mitsbishi remote. So once the tv turns off you have found your code.. but make sure before you save it you write down on something; and, it works all of the functions that you want it to. I hope that this helps a ton...
Jun 29, 2014 | Mitsubishi New Original 290P137C10 Remote...
My remote control (BN59 - 01014A) work only on short distance (1 - 1,5 m). I have a TV Samsung Led UE26C4000. I have changed batteries several times, but no results. Please help ! Thanks
Take the tv remote aparts,there is a screw in the battery compartment.I know this because i have a tv this model too.Take some Q tips soak it with some rubbing alchahols and clean the remote PCB board and wait like about 20 mins for it to dries.Put it back together again and with a new set of batteries.And take some cottons balls soak it with some rubbing alchahols and clean the tv set infer red light sensor on the tv set it self too by the tv LED power light indicaton.This solution should improve ur infer red senor reading like( 2-3 more m).
Jul 14, 2011 | Samsung Bn59-01041a Remote Control
Even with new batteries the remote is making no connection with the TV. Can it be fixed?
If you already replace the old battery try to check the battery terminal the one that is solder in the pcb, try to check the leads that holding the battery terminal if loosed, Then if battery terminal ok, Try to check IR LED sensor of the remote you should have camera or cellphone with camera then try to point the IR LED sensor to the lens of the camera and press any button then look at the monitor of the camera if there is a red light that is glowing if you see this red light it indicates that your remote is in good condition. Good day.
Jul 13, 2011 | Hitachi Televison & Video
Remote not turning tv on
if your tv set can be switch on manually then you need to replace the remote control.have you tried changing the batteries of your remote?maybe it is already dead,if you tried then buy a new remote control.
Nov 30, 2009 | RCA Televison & Video
Remotes won't turn on
ok,you changed the battery already but did you synchronize the remote to the console?beside the battery of the remote is a small red button.did you try to press this button? as well as the red button on the console?it is located on the memory card port of the wii.try it first,let me know
Dec 25, 2008 | Nintendo Wii Console
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
