Question about IBM Correcting Selectric II
Our library still regularly uses a Selectric II. Recently we have begun to notice that when trying to capitalize certain letters, the spacing seems to skip a half space ahead. As the next letter will
We opened the top of the typewriter and it does not appear to our untrained eye that anything is amiss. Everything is moving smoothly. There is nothing out of place or sticking. We have been using this typewriter for years without any issues. It is only recently that some of the keys have not been working. And only some of the time.
  • IBM Master
  • 3,594 Answers
Try replacing the element (ball) if that doesn't help then it will need a rotate adj. not a job for the untrained.
DickyO
Posted on Dec 11, 2014
2 Suggested Answers
  • 3594 Answers
SOURCE: IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
How to make use of the keys
Well it is rather easy but it does take some practice, some people prefer to adopt a method whereby they assign certain fingers for certain keys, this is done mostly for quick typing. However it does not matter how you type so long as it is comfortable for you. After a short whole you will find it quite exciting. The shift key found on the bottom left hand side of the keyboard is to do Capital letters and the CAPS key is to do THIS ALL CAPITAL LETTERS. The space bar is to make a space between words, just like a type-writer.
Don't worry, you will learn in good time.
damnor01
Nov 11, 2010 | Dell Dimension 2400 PC Desktop
The typeball will only type one letter, it doesnt seem to be able to spin to the correct letter.
You listed this this as a wheelwriter thentalk about a type ball. Is it a WW or a selectric?
DickyO
Mar 29, 2010 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
Aug 31, 2009 | Office Equipment & Supplies
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
Gapping/overlapping of letters
Its sounds like tou may need a rotate adjustment. Take it in for service.
DickyO
Sep 10, 2008 | Office Equipment & Supplies
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II Logo
78 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
