Does a Hitachi SF6500PX drain pump need to be replaced with exact same, or can another be used? If so, do you know which are suitable? Can the old pump be overhauled?
Machine won't drain or spin. It will spin when completely drained. So it seems that the pump is the issue.
  • Washing Mach... Master
  • 1,253 Answers
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
  • 22 Answers
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Posted on Oct 21, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 3230 Answers
SOURCE: G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
Posted on Mar 28, 2009
How to remove the gas tank on a 2003 Dodge Stratus
On Yahoo.com, master certified Dodge Man says: "Some newer Chrysler's actually have a drain plug on the bottom of the fuel tank, if so, it is as simple as removing it and catching it in a suitable pan, if not you could jump the fuel pump relay in the power distribution center, disconnect the fuel supply line and route into a suitable container before hand. This uses the vehicles fuel pump to drain the tank.
Always think safety, and have a fire extinguisher handy, don't try this in an enclosed area, due to flammable vapor buildup. "
May 28, 2015 | 2003 Dodge Stratus
How do I replace power steering pump on a 1993 Buick centry
place a drain pan under pump. disconnect negative battery cable. remove inlet and outlet hoses a.d let drain. remove the serpentine belt from the pulleys by loosening the automatic belt tensioner. remove the three pump mounting bolts and the pump. using a suitable pry bar remove the retaining clips from the reservoir separate the reservoir from the pump. install the reservoir to the pump with new o ring seal. remove pump pulley and put on new one.
Oct 27, 2013 | 1989 Ford Bronco II
Hitachi washing machine sf6500px washes ok but wont spin, digital signal says dE, does anyone know what that means please?
im not 100% on hitachi gear dont see alot where im from, but for most washing machines DE normally means the lid is open as they have small magnets in both the lid and frame of the washer, most machines will not begin to spin if the lid is not shut they will fill and wash but not spin purely as a safety precaution, if the lid is shut it means the lid (you may have a latch that actually locks the lid shut or just a reed switch magnet sensor that simply detects if its opened) reed switch or lid lock is broken or faulty normally pretty quick and easy to repair
Jan 18, 2011 | Sprint Hitachi P300 Cellular Phone
Will not drain and go into final spin , removed waste pipe and drained it manually , then ran another wash and same thing happened
Seems that your pump may need replacing. remove bottom panel at back of machine. You now have access to your pump. Using suitable screwdriver or grips remove retaining clips on pump pipes. Tilt Machine forward and unscrew 2 screws holding pump in position. Then remove 2 wires that go to pump. Ensure machine is unplugged. The pump is an Ask
Mar 11, 2010 | Hotpoint WMA31 Front Load Washer
OLD Hitachi 50EX13K rear projection TV now has bow shaped picture
Your convergence ic's have to be replaced along with checking all the bias resistors for exact value. Easy for me! I don't know what your electronics background is?
Oct 30, 2009 | Hitachi Televison & Video
It stops before doing full spin with a code of .. OE
The OE code means that the pump is blocked. Follow your instruction book guidance which will tell you how to check and clear the blockage, access to the pump is usually via a small removable panel at the bottom front of the machine but without knowing which exact model you have I can offer no further specific guidance.
You'll need to drain the machine as much as possible before removing the actual pump cover and most LG washers have a small tube next to the pump cover which can be withdrawn and unplugged to allow the water to drain into a suitable receptacle.
Oct 07, 2009 | LG Washing Machines
Replacing water pump on a 94 cutlas supreme instructions
REMOVAL & INSTALLATION
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or inPuddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
2.2L Engine
  1. Disconnect the negative battery cable.
  2. Properly drain the engine coolant into a suitable container.
  3. Remove the serpentine drive belt, as outlined in of this repair guide.
  4. Unfasten the water pump pulley bolts, then remove the pulley.
  5. Remove the alternator and side bracket.
  6. Disconnect the water pump hoses.
  7. Unfasten the water pump retaining bolts, then remove the water pump from the vehicle. Remove and discard the gasket. Thoroughly clean all gasket mating surfaces.
To install:
  1. Position a new water pump gasket, then install the water pump. Tighten the attaching bolts to 18 ft. lbs. (25 Nm).
  2. Install the water pump pulley and secure with the retaining bolts. Tighten the bolts to 22 ft. lbs. (30 Nm).
  3. Attach the water pump hoses.
  4. Install the alternator bracket and the alternator.
  5. Install the serpentine drive belt.
  6. Properly refill the engine cooling system using the correct type and amount of coolant.
  7. Connect the negative battery cable.
Apr 05, 2009 | 1988 Oldsmobile Cutlass Supreme
Hotpoint Aqualtis Error code F11
please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
Jun 27, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
