Question about Cell Phones
I have a RCA 24 inch LCD full HDTV it updated now when I turn it on it is just a black screen and the menu and input buttons as well volume and channel buttons on the tv don;t work.
Is there a master reset?
    Sergeant:
    Champion:
  • 214 Answers
You may try to unplug it for an hour or two and then try it again.
Posted on Dec 10, 2014
SOURCE: is lcd screen faulty
It's probably a faulty contact strip for the LCD display. There is a ribbon cable with VERY fine tracks on it that clamps into a connector on the main board. If this has shifted, you will get the problems you describe. It can be unclamped, but often breaks the lugs.
If you wish it to be repaired it is possible, but may be a 50-50 for a positive outcome.
If it is still under contract or warranty, then go through the providers, otherwise you haven't anything to loose by having a go.
Buy a decent set of jewlers screwdirivers, and prise up the edge of the clamp. It's like a hinge with catches at the end. Remove and replace the ribbon sheet(cable) and click back into place.
This may solve the problem, or cause more of a problem. as I said - 50 - 50% success rate.
Posted on Jun 21, 2008
SOURCE: Need Master Reset Instructions
The same exact problem is happening with my phone right now. if you need to use it immediately then turn it on and quickly go to the settings menu to turn off auto-lock and try to avoid pressing the side buttons, don't let the phone lock by itself before you get to the settings otherwise you have to take the battery out and try again.
Posted on Aug 25, 2008
Bajanguru
  • 7752 Answers
SOURCE: my volume button doesnt work
take the phone to amobile service center and have them fix it for you.
Posted on Sep 21, 2008
SOURCE: Frozen Screen
just simply tack out the battery to turn it off
Posted on Dec 15, 2008
soldierruel
  • 175 Answers
SOURCE: Main menu screen problem
I think the degitizer (touch screen ) is faulty.
Replace it.
Posted on May 08, 2009
RCA 24" Class LED-LCD 1080p 60Hz HDTV 1.7" ultra-slim, LED24A45RQ USB input
One use for the USB inputs on flat screens is to allow you to connect a USB stick or external hard drive and watch or view any external files you have.
Hope that helps!
Aug 11, 2014 | RCA 24" Class LED-LCD 1080p 60Hz HDTV 1.7"...
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
