Why can't I charge my mp3 player?
When i try to charge EM648VIDB 16gb mp3 player with my PC I get a blank screen. I don't see a battery show me it charging,why is that and how can I fix it?
    Sergeant:
  • 399 Answers
It could be that your USB cable is just a synch cable, not a charging cable. A synch cable connects your MP3 player to your computer so you can transfer (automatically or manually) MP3 files between the two. If you can see the player in the Windows Explorer on your computer as a "Removable Device", it is a sync cable.
Posted on Dec 21, 2014
SOURCE: Rio Carbon Pearl mp3 won't charge
tr y to get a new battery. but it is tricky to get the old one out so take it to a store that deal with it.
Posted on Dec 20, 2007
  • 3 Answers
SOURCE: Battery won't show full charge
I called sandisk. You have to have service pack 2 on your windows XP and you have to have Windows Media Player version 10 or 11. One one of my laptops I had version 9 and it wouldn't work, I changed laptops and it works just fine.
Posted on Jan 26, 2008
renx
  • 71 Answers
SOURCE: Frozen and stuck on screen disconnected
Hold the power off button continuously for 15 seconds. This should force a shutdown and reboot.
Posted on Apr 21, 2009
dragonclu
  • 3 Answers
SOURCE: I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Posted on May 13, 2009
  • 608 Answers
SOURCE: MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Posted on Mar 28, 2010
My ce 2100 doesnt work anymore.. i plug it in and at shows a battery bar charging for a few minutes then the screen goes blank and i can turn it on or even charge it again can i change the battery?
yes. Once you plug it in it should automatically start charging. If the screen goes blank leave it for about 15 min. Unplug it and start it to see if it has charge. I hope this solution has been helpful.
Sep 24, 2010 | Rio CE2100 MP3 Player
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary.
To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
Mp4 player freeze
if you can still see and detect it with your pc there may be a newer firmware update to fix this issue try and find the firmware and flashing utility from the manufacturer and see if that helps
Sep 24, 2009 | Digital Mind Corporation iQ Sound...
Connection and battery charging
Try to turn it off while connected, mine works normally and I can turn it on to use it while connected to the pc cable and then it doesn't communicate with the pc, or charge I think. When I turn it off it goes blank for a moment and then shows the USB symbol and communicates with the computer.
May 28, 2009 | Samsung YP-Z5 MP3 Player
My rca mp3player m42series screen will not show anything
You need to charge it for at least 3 house.
To charge the battery. Hook to usb device of your computer for about 3 hours.
Dec 25, 2008 | RCA M4204 MP3 Player
63 people viewed this question
 Grubhead
Grubhead
