Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
I have a red ghosting problem on my TV.
Pinkish shadow shows up on the left edge of edges in picture.
  • Sony Master
  • 1,249 Answers
Set should have magic focus. use it or adjust convergence manually.
Posted on Dec 10, 2014
ctf1800
  • 4402 Answers
SOURCE: sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Posted on Feb 20, 2008
frankgant
  • 250 Answers
SOURCE: Red & Green ghosting on one side
More than likely yes you've had an IC go out. I would replace both. It never hurts, and if one has gone out the other will eventually follow. IC's are cheap and who wants to do it twice. :)
Posted on Jul 07, 2008
Matampong
  • 153 Answers
SOURCE: TV showing Red shadows when viewing the picture
Open the TV set and at the end of the CRT, there is a Circuit board (Video baord) where color adjustments are manually done there. OK, normally there are cracks or cold solders on the terminal of the components which can be the cause. You'll need a technician to do the re-soldering of the terminals. cheers.
Posted on Nov 06, 2008
  • 2920 Answers
SOURCE: My Sony KP48V90 tv has three images on screen
you need to have the tv converged
Posted on Nov 22, 2008
SOURCE: Picture has ghosting, a shadow outline to the left
what is the "best solution" as I too am having this problem on the same tv?
Thanks.
Posted on Feb 22, 2010
Picture has a red shadow. especially
Convergence problem on rear projection CRT TVs.
Apr 19, 2010 | Televison & Video
Not showing entire image on screen
It's possible that your projector doesn't natively support your display resolution, but to know more it would be best if you could provide the following details:
Projector Model
PC Model
Windows Version
Windows Resolution/Refresh Rate
Display type (if laptop) cloned/extended, etc
Thanks!
Feb 18, 2008 | Sharp XR-10X Multimedia Projector
Model 50UX58K - picture has distortion & shadow on right side of screen
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Eric
Sep 01, 2009 | Hitachi 50UX58K 50" Rear Projection...
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Red and blue shadows on my sony wega
hello it sound like convergance chips might be the trouble
shaun
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
