Question about Dewalt Drills
How do I add the auxiliary handle to my DeWalt 510 Hammer drill? The 511 manual shows a hinged collar, not found on the handle I have or on any I've seen for sale. That sort would make it easy and sma
How do I add the auxiliary handle to my DeWalt 510 Hammer drill? The 511 manual shows a hinged collar, not found on the handle I have or on any I've seen for sale. That sort would make it easy and smarter. The current sort I have is a solid collar.
    Sergeant:
  • 209 Answers
Unscrew the handle from the collar and see if it will open wide enough to slide over the chuck and onto the drill neck.
If not, you may have to remove the chuck. Open the chuck jaws completely and look down inside you will see the head of the screw which is holding the chuck onto the drill.
Posted on Dec 10, 2014
  • 313 Answers
SOURCE: Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
Posted on Jun 08, 2008
  • 313 Answers
SOURCE: dewalt dc926 hammerdrill chuck do not stay lock in reverse
chuck should be replaced to parts # 33007575 newer style.
Posted on Aug 11, 2008
emissionwiz
  • 76682 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
emissionwiz
  • 76682 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
rowdy45176
  • 2176 Answers
SOURCE: Replaceing chuck on a Dewalt Dw511 1/2" hammer drill.
Open the chuck jaws and you will see a screw in the center of chuck, it is left hand thread. remove it and use a large bent handle allen wrench putting the short portion in the jaws and tightening. Shift the drill to the low position and have the clutch in the drill only position. place the handle of the wrench at about a 30 degree angle to strike it counterclockwise. put the chuck on a block of wood or workbench and hit it, this might take a couple times but it will come off. Let me know if you still need help
Posted on Mar 09, 2009
Dewalt xrp stuck in hammer mode cant move selector to drill or number selections
I am assuming you are talking about not being able to move the "Mode Control Collar" and unless you can get it out of hammer mode, you will not be able to change the torque collar either.
If you feel comfortable taking it apart AND its no longer under warranty, my best guess without seeing the tool will be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
Apr 29, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
How do I remove the chuck on my dewalt 18 volt xrp hammer drill
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting. Remove the battery! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you, and if not, explain what is happening.
Nov 28, 2010 | Dewalt Drills
How to remove the chuck from a dewalt cordless hammer drill?
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Sep 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How do I remove a dewalt chuck
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Jul 23, 2010 | Dewalt DCD970KL XRP HeavyDuty XRP 12"...
Got a cordless18v dewalt drill that wont go onto its hammer setting
Try pressing the trigger at the same time as turning the selector collar. If you still can't get it to turn try using an air nozzle to really blow everything really clean.
Oct 14, 2009 | Dewalt Drills
How to switch to hammer on dc935
Turn the black clutch adjusting collar all the way to the hammer symbol. It will be just past the Drill symbol on the collar. Then when you press the bit against the material you will feel the vibrations.
Oct 14, 2009 | Dewalt 18 Volt Compact Drill Kit
How to select hammer action
turn the torque adjustment collar until the hammer is selected (there is a picture of a hammer instead of a number there)
Oct 01, 2009 | Dewalt DC925 Cordless Drill
Drill will rotate but will not hammer under load
most of these types of tools have a manual switch it will be located on the body of the drill just behind the chuck on top or bottom or oposit the grip handle. some models have 2 switches.you want to make sure the switch points to the picture that shows a hammer and drill together.also rember it needs to have down pressure for the hammer part to activate.
May 19, 2009 | Dewalt 1 9/16" Rotary Hammer Drill D25551k
Drills Logo
90 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
