VISIO M470SL remote does not work. The remote is OK. Is it the IR sensor or the main board that needs to be replaced? VISIO M470SL remote does not work. The
The buttons on the side work(volume,channel,etc) but the remote does not. The remote has been checked. It works.
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
If the standby light is ON at the front panel; when you power ON the set, and if the remote control is found OK too; the remote control sensor inside the TV is defective. Before doing anything, try by reset the set once.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 10, 2014
  • 3640 Answers
SOURCE: hi, remote not working and unable to change
if your remote is for cable, then you have to push the cable button, then change channels. volume will work only on tv mode.
Posted on Oct 06, 2009
  • 8457 Answers
SOURCE: Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Posted on Jan 02, 2010
welcomejee
  • 10594 Answers
SOURCE: Philips 47PFL3603D LCD TV -
There could be many reasons like IR pins not soldered properly, it is not getting +B supply or IR output signal is blocked, buffer transistor on same board is bad etc etc
Replacement IR Board is available for $6 at Encompass.com so I would suggest to replace complete board instead of IR Sensor.
Hope these info will help you.
Thanks.
Posted on Jan 05, 2011
SOURCE: I have a Sony Bravia
Welcome to the world of Sony **** Bravia and their **** customer service. You will find this is a HEAVILY reported problem and Sony will gladly ignore it and expect you to cough up $200 to trade out a 2 year old TV. Yes, it is the IR board. Yes, I will never buy another anything Sony.
Posted on Jul 02, 2011
gopakumarg43
  • 75571 Answers
SOURCE: visio remote sensor does not respond
Hello
You may not have set the remot to TV with its set up code. If you have did it, and still there is no response by the TV to remote control, the remote sensor inside the tV is faulty. This is a three terminal component, can be located behind the remote sensor window at it front panel. you have to open the TV to access this component. Will look brownish black in color, and can be easly replaced. The component can be bought from most of the elctronic spare part selling shops at your town. The images of some types are given here.
2_27_2012_11_45_16_am.jpg2_27_2012_11_45_37_am.jpg2_27_2012_11_46_00_am.jpg2_27_2012_11_46_21_am.jpg
Posted on Feb 27, 2012
Touch pad not working
reset all pluges on board.
Mar 07, 2014 | LG 42CS560 42 Class LCD HDTV
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
Feb 09, 2013 | Vizio Televison & Video
Visio M470SV will not accept signal from remote
Replace remote batteries, try a universal remote, and look for a Reset button on your remote. Once you've tried all three things, let us know anything else that you can. All we really know at this point is that your remote isn't working.
Jan 31, 2013 | Televison & Video
Does the power board on a tv control the buttons on tv and remote sensor
no i would suspect the the IR board or main board ..also check remote with a ir remote tester to make sure it works
Jan 07, 2013 | Toshiba 46SL417U LCD TV
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Hi I recently change the main board of my protron 32"pltv television and my remote control does not work anymore, do I need to change the IR remote receiver
You will need the scope to find out if the IR receiver is putting out the signal to the main board, or take a chance by replacing the IR board. Did the remote work before changing the main board?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 12, 2010 | Protron PLTV-32 Television
Remote control does not work altho tested ok
There are two parts in the TV that could be causing this issue. It is either a defective IR board in the TV or defective main board. The IR sensor on the IR board picks up the signal from the TV and sends it to the main board that decodes it.
It is also possible there is a loose connection form the IR board and main board. The only way to check which of the above mention failures is causing the remote control not to work is to check the voltages along the line with a digital multimeter to match the ones in the service manual.
Oct 08, 2009 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Jun 22, 2009 | LG 47LC7DF 47 in. LCD HDTV
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
