Why does my ceramic heater keep turning off
New tower ceramic technology recently starting to turn off - temp deft not reached and on level surface Please can you say why this is happening there is a little green light flashing with bigger red dot lit Sometimes restarts but usually doesn't Starts again immediately after pulling out main plug but only for about a minute Thank you
  • 45 Answers
Without other specifics I can only postulate that it's more than likely overheating, and perhaps it's location stifled
Posted on Dec 13, 2014
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: Flashing Red Power Light
i had to replace the power supply
Posted on Oct 26, 2007
ctf1800
  • 4402 Answers
SOURCE: TV Shuts down
convergence amp IC's i would start with.
Posted on Dec 03, 2007
  • 45 Answers
SOURCE: Problems with my TV
change your bulb in the TV. That should do the trick
Posted on Jan 23, 2008
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
What should I do?
Turn it off and Do not use! Return it to the place of purchase to be inspected.
Nov 30, 2015 | DeLonghi Safeheat 24" Tower Ceramic Heater
Heater switching off for no reason
The level safety device may be defective.
Jan 28, 2014 | DeLonghi TCH6590ER Ceramic Heater
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
My Lasko 5307 oscillating ceramic tower simply does not "turn on" .... what's up?
Electricity is not suitable for use by you....
Check power point with another appliance. Check heater switch, high temp, etc....
Oct 16, 2013 | Lasko 5307 Oscillating Ceramic Tower...
I have a Pentair Mastertemp 400. It worked fine for 3 years until the temp sensor went out and both (internal and external) were replaced about a year ago. It then worked fine for about another 7-8...
You might have a much bigger issue than the temp sensor. When the heater is running hold the "pool" or the "spa" button for 12 seconds. This will show the exhaust temp, if the temp is rising above 375 degrees with in 1-2 mins then your not getting the heat out of the heat exchanger.
One other thing to check would be an external by-pass. If you have an external by-pass make sure the by-pass is set correctly. Opened or closed to much can cause the problem your having.
Mar 04, 2017 | Pentair MasterTemp 400000 BTU Pool and Spa...
Heat will not turn off.Removed thermostat wile
Hello
Could be a stuck control relay,Tsat completes a circut for this relay to engage,once relay contacts are closed heater will start.and stay on until you reach temp.
once temp is reached relay will open and heat will shut down.
By disconnecting all power to heater your forceing relay to open.or simulating a satisfied temp.
I would have a service tech look at your control relay and t stat.
Jan 28, 2010 | Goodman Heating & Cooling
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Dec 13, 2007 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
