Watt can I try water fills and drains fine just want wash I have a bush new machine 8kg load
Nothink yet just cleaned filter watt could this be as I am in need of this to be fixed asap
Something wrong with the motor or its connections to the controller board
or the controller board motor control parts have failed
its a job for a tech
if its under warrenty then get back to the supplier {like argos etc} or the maker under makers warrenty
Posted on Dec 10, 2014
SOURCE: E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water supply error -Not enough water entering the W/M.
Try check water supply line is on and not have any kinked.
Posted on Jun 23, 2008
  • 1294 Answers
SOURCE: Washing machine fills with water when not in use.
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Posted on Feb 11, 2008
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
SOURCE: My older Kenmore washing machine isn't draining
when you close the lid can you hear a click from the switch?if not replace lid switch
Posted on Oct 09, 2009
Testimonial: "Perfect! And such a simple solution. To think I was just going to buy a new washer when all I needed to do was fix a little lid switch. Thank you!!!"
  • 662 Answers
SOURCE: really bad smell from drum?
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the hose to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting. Being the first time you shd note what you doing, what goes where. You certainly don't need techs for this; and techs who come are useless anyway.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pl give me a ‘very helpful’ rating for the free help, thanks!
Posted on Jun 20, 2010
Water is leaking from washer. Could the filter be clogged?
Washer Filter Plug Kit (part #285868) - How To Replace ...
? 3:59
https://www.youtube.com/watch?v=djJQhM-R8JQ
Aug 23, 2011 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace the FilterPlug Kit on top load direct drive Whirlpool ...
How To Clean Your Washing Machine Filter - YouTube
? 2:43
https://www.youtube.com/watch?v=Mmvr4Xn2W1w
Jun 17, 2012 - Uploaded by Kenneth Watt
This short video shows how to clear the drain filter on many front loading washing machines, in this case on an ...
[PDF]Owner's Manual
shop.amana.com/assets/pdfs/literature/40068302.PDF
Dec 30, 2015 | Amana Washing Machines
Where is the filter located on an unidentified washing machine?
Inlet or drain-filter????
? 2:43
For more washing machine help please see our website at ... Far more helpful than the wretched manual that came with ourwashing machine. :) ... I just did this to my washing machine, the filter was blocked up with wool, ...
[PDF]Owner's Manual
manual stays with washer. Contents. Important ... Keep this manual and your sales receipt together in a safe place for ... Amana Appliances offers long-term.
How to Empty and Clean Out Your Washer's Drain Pump Filter
www.homesavvyatoz.com/washer-drain-pump-filter/
Oct 13, 2011 - Do you have a front load clothes washing machine? Have you every wondered what happens to that spare change you occasionally forget to ...
Amana NFW7300WW Washer Locate drain pump filter
Dec 30, 2015 | Washing Machines
My bush washing machine fills with water drains water want wash.
timer controls it so it is either that or drum drive system-u didn't say if it is or isn't agitating or spinning
Dec 09, 2014 | Washing Machines
What does the fault code E18 mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
My Fisher Paykel 8kg Intuative Washing Machine doesn't work on the Eco Wash cycle
Your eco Diverter valve has failed. this is a wax solenoid and is a common part to fail, it is located under the machine in the drain hose next to the drain pump.
Check out the below link for a service manual
Link:
Mar 10, 2012 | Fisher and Paykel Washing Machines
Problem with the flow rate to the entrance valves
Turn the water valves off and then unhook the water supply hoses from the machine. Look into the hole the hoses were connected to. Use a pliers to grab the tab on the filter screen(s) and pull them out of the water fill valve(s). Clean, reinstall, and reconnect hoses and turn valves back on. Most often you will find that the cold water supply is the culprit.
Feb 02, 2009 | LG WFT1071TP Top Load Washer
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
Dec 11, 2007 | GE Energy Star WCVH6260F Front Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Fills, washes, but won't drain or spin
Possible your outlet filter is blocked, it needs periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first.
Jun 13, 2007 | GE WWSE5200B Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
