Question about Canon ImageRunner 2270 | IR2270 |
Hi......i have canon IR2270, the problem is when i scann A4R size by using ADF the copy would be less than a half , also the scan size option is set on A4R.but idont have a the same issue as im copyin
I tried another ADF unit from another device for the same product but the problem is the same.
old marine
  • 2039 Answers
SOURCE: Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
Posted on May 08, 2008
checkitright
  • 1362 Answers
SOURCE: Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Posted on Oct 07, 2008
komguy
  • 2306 Answers
SOURCE: hi, my canon mx310 is showing a daRK line when we
Use a flashlight and look closely at the narrow glass next to the platen glass. I usually find a spot of white out on the glass causing the streak. Also a dark spot on the white guide above the glass will cause a streak like you mentioned.
Posted on Jun 22, 2009
old marine
  • 2039 Answers
SOURCE: having problem copying from ADF
On this model, the Intensity needs to be set to 'Manual' to make copies from the ADF.
1. Press the 'Settings' button repeatedly until 'Intensity' is displayed
2. Press the left or right arrow until 'Manual Adjust' is displayed, then press the 'OK' button
3. Press the left button to decrease the intensity, or the right button to increase the intensity, then press the 'OK' button
4. Press the 'Back' button repeatedly to return to the Copy standby mode
To return to 'Auto Adjust', follow the above instructions selecting 'Auto Adjust' at step 2, and skipping step 3
Posted on Aug 28, 2009
old marine
  • 2039 Answers
SOURCE: Scanning a document from the ADF results in a line
Lift the scanner cover so that you can see the platen glass. Look to the left of the large sheet of glass and you will see a narrow strip of glass. This is the area used to scan documents fed from the ADF. Make sure that this glass is very clean. Use a damp cloth to clean any dirt or buildup.
Posted on Feb 10, 2010
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
Copy is not coming in centre of the paper when using A4R size by Manual bypass table
first, did you manage the sideway rails to hold the paper centered?
Did You put the A4R paper in bypass horizontally?(the A4R way)
Did You select the A4R paper size for manual bypass settings?
I hope that something of these helps You!
Feb 15, 2011 | Canon imageRUNNER 400S Copier
How to scan in two faces in one side for exmaple ID in photocopy scan and printer " canon IR3045N"
select special function on screen>image combination>2 on 1>original size a5R(if u r copying on a4R paper then original size a5) then scan both faces to be printed and >done
Feb 03, 2011 | Canon Office Equipment & Supplies
Full page is not copied
Hi, did you place paper in tray also horizontal? the paper in tray and on glass must be horizontal if you want to copy A4R size.
DO NOT forget to adjust the blue paper size indicator on paper tray to A4R also.
Also under user mode, under copy sett. you can find option for auto rotate, so copier will adjust size automaticaly.
Jul 17, 2010 | Canon iR 2016i Black and White Copier
My copy machine is D 861 digita.when i make a copy
If you're using the automatic document feeder (ADF) to scan the document, make sure the ADF scanner area is very clean. This is the area of the platen glass to the right side. Also make sure that you don't have reduction set on the copy size.
Jan 18, 2010 | Canon ImageClass D861 Printer
Paper jams when using the ADF. Canon IC D780
When using ADF
Note:
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Nov 30, 2009 | Canon Office Equipment & Supplies
May 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Canon ImageRunner 2270 | IR2270 | Logo
50 people viewed this question
old marine
old marine
