Question about Toshiba Computers & Internet
How to solve low disk space warning on my Windows 7 laptop?
Hey, this morning, I had received a warning saying: "You are running out of disk space on Local Disk (C:). To free space on this drive by deleting old or unnecessary files..." I had already followed its suggestions to delete all old or useless files and folders there. But, the result is not so good. The same message warning popped out again several minutes ago. What can I do to solve this low memory problem? I have no files or folders that can be deleted. Please, help me!
It sounds like you have too much running in the start menu. If you go there you have to be careful what you stop from loading. Go to your start and left click. The search box at the bottom type msconfig Go to the startup tab. Anything like Adobe reader, Java, any toolbars, quicktime, realplayer or anything that doesn't need to start when you boot the computer uncheck the box on the left beside it. When you click apply and ok it will ask you to restart the computer. After you do a box will popup and you can check the box and click and you won't see it again. But like I said you can stop the wrong things there. If you don't feel comfortable trying it get someone you know who is tech savvy to help you. Anything Microsoft, Intel, or with your computer brand name needs to stay.
Posted on Dec 10, 2014
4 Suggested Answers
  • 159 Answers
SOURCE: low virtual memory
Virtual memory means you're running out of memory, so it's using your hard drive storage as memory. This is slow. This is an indication you: Have too little memory and need to run fewer programs or install more memory; and also increase the size of your virtual memory, which will also make your disk space tighter. If you are really pinching the computer that badly, you may want to consider buying a new laptop altogether -- the prices have come down a -lot- just in the 2 1/2 years since you bought that. Anyway, to work around the immediate problem:
Your Gateway came with Windows XP Home Edition. Click Start: Control Panels. See if you can find the Performance control panel, possibly by switching to "Classic view." In there, look for the memory tab. Find the virtual memory section. It may be set to "Let Windows decide." change it to at least 1000mb.
You can get a bigger hard drive (after buying an external case to move stuff over) and upgrade your memory to as much as 1.25gb; but you may find those purchases to not be sensible relative to the price of a new laptop. Memory is cheap and relatively easy; the hard drive is more difficult and will set you back at least $100 if you do it yourself.
Posted on Dec 05, 2008
venexcsd
  • 1185 Answers
SOURCE: Cannot delete files from D drive
Try deleting the files inside the folder first
If not
Copy some of the files off the drive onto a DVD or two that will make working space on your hard drive
Posted on Jun 25, 2009
aaronyen0
  • 3 Answers
SOURCE: How to cope with Laptop C partition low disk space error problem
When there is low disk space error, just delete all unwanted partition files and uninstall all useless programs.
And then, use disk management to resize your computer partition spaces.
But, if you can not resize all partition space by yourself, you also can use some related partition resizing tools to help you out.
Here is a video tutorial for you to go on:
https://www.youtube.com/watch?v=6jCeT7CbsKk
No matter what happens, always make partition data well in case of data loss problems.
Posted on Dec 02, 2014
You can try and compress your file this will give you 15 to 20 percent more space. Also, download CCleaner and run it this will also help clean up disk space. And run disk cleaner and last run a defrag
Nov 27, 2014 | Toshiba Computers & Internet
Tip
Low Disk Space in Windows XP
Click on Start | Run, type Regedit, and click on OK. Browse to HKEY_CURRENT _USER\
Software\Microsoft\Windows\ CurrentVersion\Policies\Explorer. If there's no DWORD value
there, create a new one called NoLowDiskSpaceChecks.
Once you are in the Explorer folder, select Edit from the menu, select New, and choose DWORD
value. Now double-click on the new DWORD and assign it the value 1. Log off and log on once
more, and you won't receive the warning again. Note that the warning will be turned off for
all your hard drives.
1. Start the registry editor (regedit.exe).
2. Navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer.
3. Go to the Edit menu, and select New - DWORD value.
4. Enter a name of NoLowDiskSpaceChecks, and press Enter.
5. Double-click the new value, set it to 1, and click OK.
6. Close the registry editor.
7. Log off and log on for the change to take effect.
REM copy here regini
"NoLowDiskSpaceChecks" = REG_DWORD 1 REM end copy here
If you want to keep the partition intact, and just want to get rid of the low
space warnings:
Control Panel (Classic view) > Administrative Toots > Computer Management >
highlight Disk Management in the left pane > right
click in the right pane on the D partition and select Change Drive Letter and
Paths > Click the Remove button > click OK
If you want to access the volume later, you can reassign a drive letter. The
data on the disk will not be damaged.
on May 10, 2010 | Computers & Internet
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
Nov 27, 2014 | Computers & Internet
Clean up disk space window 7, already deleted unwanted items
If you run Disc Cleanup, in accessories, that will give the option to remove temporary and hidden files.
Sep 28, 2014 | Computers & Internet
Why is my laptop window 7 running very slow?
Uncheck tools in start up menu that you don't absolutely need on startup. Select selective start up and deselect startup items. Click apply, a window will pop up that says windows startup has been changed. Select do not show this box again and then OK. Delete browsing history and cookies. Go to C:\ windows temp files and select all, then hit the delete key. Movies and pics and music take up a lot of disk space and can slow down you unit. Manage your add ons in the settings menu. Disable add ons, they slow down your unit. Good luck I hope this solves your problem. Please post a solved comment on fixya, so I receive credit for the solve. This will increase my ranking on fixya.com That is how I get paid. By knowing I am helping!!!!
Apr 22, 2014 | Computers & Internet
Drive Properties say free space 12.6GB Acronis Disk Director says 109GB which is correct?
Yes take a look at your drive manager in windows.
(Right click) Computer - Manage - Disk Management.
This will show you how your drives are setup.
Mar 26, 2013 | Microsoft Windows 7 Home Premium Operating...
My laptop keeps posting low disk space. how can I fix this?
You need to delete items to free up space. Not much else, but maybe run a defrag and disk cleanup.
Dec 09, 2012 | HP Computers & Internet
Window 7 won't boot up
BECAUSE THE FIX IS LONG GO TO http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly
Apr 15, 2012 | Computers & Internet
I do have the latest windows 7 on my laptop but when I try to open a document sent 2 me in my emails it says there is not enough space?
You could try running Disk Cleanup.
Click the Windows button and type Disk Cleanup in the search box. Select the disk you want space on. For more details see http://windows.microsoft.com/en-US/windows-vista/Delete-files-using-Disk-Cleanup
Feb 28, 2011 | Acer Aspire 6920 Notebook PC
Screen is dull & laptop automatically goes into herbernate?
pls try to go in safe mode and disable this warning system of low disk space from control panel and then free up some disk space for ur system to boot properly
press F2 or F8 for safe mode at startup
Feb 24, 2009 | Acer Aspire 1640Z Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
