Question about Thermador Refrigerators
It stopped making ice
It just stopped to make ice 2 weeks ago. I have tried emptying I did not see anything. I WAS TOLD THERE IS A BOTTON for ice I can not located. Please help.
    Scholar:
    New Friend:
  • 80 Answers
Hey Sara,
Do an online search for your specific model and download a users manual. My ice maker (different brand) also has a reset button that set everything right but it was hard to find!
Also, don't expect it come to life immediately. I pushed the magic button on my neighbors fridge and it fixed itself 20 minutes after I left!
all the best!
Posted on Dec 11, 2014
  • 92 Answers
SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Posted on Oct 31, 2007
  • 262 Answers
SOURCE: Ice maker not making ice
you need a module cant remember the part number off the top of my head but go to repair clinic .com or your local appliance parts dealer with model and serial # in hand it may be quicker for you to get a new ice maker and easier
Posted on Dec 04, 2007
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
  • 32 Answers
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Posted on Sep 28, 2008
tborn6
  • 700 Answers
SOURCE: Ice maker isn't making ice...
there appears to be a problem with 1. the temperature needs to be turned down to produce Ice. also is the fill tube frozen where the water goes into the ice maker sometime you have to thaw it to get the ice out of it and the reset the maker too. Let me know if this helped and if it did not don't rate and ask another question from me and I'll be galad to help. If it did would you please rate this solution please. Thanks for using FixYa.
Posted on Jan 01, 2009
Sa 6400
If you just removed the ice from the front of the panels there is still a lot ice behind the panels. A complete defrost will be necessary. You may have a defrost problem. If you remove the panels you could check the defrost heater for continuity. if it is good then the defrost thermostat or timer could be the culprit.
May 15, 2014 | Kenmore Refrigerators
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
Ice maker stops making ice
the thermostat is playing up,,,thats the part that tells the frezer how cold it is and when to switch on or off!
but its not saying much right now!!! as its broken
Jul 03, 2010 | Maytag MCD2257 Side by Side Refrigerator
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Jan 01, 2009 | Refrigerators
ICE MAKING NOT WORKING ON MY KENMORE SIDE BY SIDE
Hello Heavensentme..
Since you pointed out that you don't have a restriction that limits water flow to your fridge.. then you may have a bad inlet valve that allows that same water to refill the ice tray or.. the switch that senses the ice bin is full is stopping ice from being produced.. The motor that rotates the ice tray may also be defective.. .. If possible,, can you empty your freezer compartment and let it thaw out and then try a fresh start so that you know you don't have any ice build up that is stopping the ice tray motor from rotating or the inlet for water isn't frozen? Otherwise.. they aren't that complicated but you kinda have to know what to look for and what to not touch in order to repair them.. Not sure this helped or not but hope so,,,
Regards
Rick
Nov 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Aug 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
243 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
