Question about Amana Washing Machines
I replaced the pump and i still get nd, drained the lines ect amana nfw-7200tw
Replaced pump check drains ect
  • 1 more comment
  • Anonymous Dec 12, 2014
    jobs a goodan!!!! great work!!
    a tip for washers is hair die like sodum peroxide you can get it from the £1 shop wash the machine out once every 6 months with hair peroxide you can also add a drop of oxy this will totally clean it out if you get trapped hair then a concentrate of hair die will disolve the hairs etc also
    i forget to say too keep the old pump its prob aok so dont chuck it ...!! try too test it them sell it on ebay or keep for another day you can usually sell them easy if its known working a quick test with a connection too it from mains will tell you its ok if the motor runs etc if you keep it put it in a vaccume storage bag and spray it all with like wd40 or oil spray before you store it
Http://www.partselect.com/Models/NFW7200TW/
something tapped in the drum skin sock plastic bag etc got a dog dog bags ?????
reset the error??? did you do this
check the drain to waste is aok>>>
and all pipes are clear
drum to pump
check out the exploded views at the link above
Posted on Dec 10, 2014
Testimonial: "Hey thanks I found that it had hair in the drain in the drum, I pulled a big chunk out from the pump hose, I also poored a bucket of hoy water in the drum and some bleach let it set for awhil and it working great, its done 6 loades today, Matt"
I have an amana front load washer nfw7200tw10 I replaced the drain pump and still get ND error
I had the same problem, not sure it was your pump, load it with a bucket of hot water and some bleach, turn it on and let it run through a short cycle, the hot water and bleach can clean the sensor and the screen in the bottom going down to the pump, did water drain out when you took the lines loose, if it did its a good sign, most people dont realize you use only a quarter or less cup of soap in this washer, it will get the sensor water sensor dirty and the washer thinks it has water when it doesnt, the pump cant drain cause there is no water, . try the hot water trick, rmember use a bucket and as hot a water as you can, probably hair sudds and who know what is blocking the sensor, mine was hair, from my little girl, Matt
Jan 27, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Amana washer nfw7200tw codes nd
ND is for "no drain" check for plugged up drain line or filter.
Jul 16, 2014 | Amana Washing Machines
What does code nd mean?
Hi Chayna,
"ND" means no drain.The door will not unlock and the unit will not wash or rinse until the water is drained from the washer. You need to pull the washer forward and remove the screws coming into the back panel. Remove the back panel and you can see the drain pump mounted to the floor below the tub. You need to be ready with a wet vac or a lot of towels because the next part is disconnecting the hoses from the drain pump. Make sure the washer is unplugged, then disconnect the hoses and remove the drain pump. Check for any debris in the drain pump. If you find nothing, then replace the drain pump. Otherwise just remove the debris and you'll be good to go again.
May 06, 2014 | Amana Washing Machines
Hi there. I have an Amana HD washer NFW7200TW and I am getting an "nd" error code. I have pulled the pump apart to check for blockage and have even replaced the pump, but I am still not able to get the...
I have had this issue (with another model) somehow a sock got lodge in the line by getting in between the tub and the frame of the washing machine. In any event it sounds like the problem lies with the cycle switch
Oct 23, 2013 | Amana Washing Machines
Amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Nov 05, 2011 | Amana Washing Machines
My amana front load washer has Nd flashing and won't open door? What does Nd stand for?
The ND error code means NO DRAIN, why it comes up is because the computer thinks that within the normal times it takes to drain the water from the tub it hasnt drained in that time.
Things that will cause it to not drain in the normal time is oversudsing becuase too much detergent was added.
Or something such as lint in the drain pump filter screen restricting the water flow into the pump
Gene
Aug 17, 2011 | Amana Washing Machines
What does error code 5D mean for Amana NFw 7200tw? I have had more problems with this machine.
Look under the top or inside the lower service panel and you will find a tech sheet that will explain the code and how to do testing and diagnosis.
Mar 21, 2010 | Washing Machines
Code nd...Washer will not drain.
Check the following to address the no draining issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 02, 2009 | Maytag Washing Machines
Washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Oct 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
173 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
