Question about Kitchen Ranges
My GE electric oven flashed F2. The broiler came on by itself. I turned off breaker for over an hour and it came back on agsin once breaker was turned back on. What's the problem? Can I remove the broiler burners and still use my oven and range?
  • 932 Answers
Deb,
Here is a website that has some fault codes that might help you.
GE Fault Codes AppliancePartsPros com
Posted on Dec 10, 2014
F7 error built-in oven
F7 is a stuck keypad error. Sometimes you can push every pad at random several times each to unstick the keypad.
If that fails the ERC(clock) will have to be replaced.
Dec 04, 2009 | GE 30" Built-In Single Electric Wall Oven...
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Oven won't turn off!
it probably needed to reset computer/electroics
but i would call customer service for the brand it is a dangerous thing to play with.
make sure there were no recalls also.
Apr 05, 2017 | Maytag CWE5800A Electric Double Oven
F2 error
what is solution
Dec 08, 2007 | Ovens
F2 CODE BROILER ELEMENET WILL NOT TURN OFF
Either the relay on the control board is stuck and allowing power to the element or the element is shorted to ground.
Nov 10, 2007 | GE Spectra JBP78 Electric Kitchen Range
GE Range Spectra oven not working
F2 is an indication of an oven temperature sensor problem. Usually this is a problem with the oven sensor itself, or the relay contacts on the Electronic Range Control (ERC) board. If you had a close lightening strike, I would suspect that the contacts on the ERC are probably bad. It probably wouldn't hurt to replace the oven sensor as well. I hope this helps you.
Jun 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
97 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
