Question about ASUS Computers & Internet
Asus g50 has no boot mgr, and when i try to reload windows it wont recognize any hdd?
I was using my asus laptop, and it froze. I hard restarted, and it came up with a black screen after setup that says no boot mgr. I tried to relaod windows to fix it but can get it to recognize a hdd. I tried using a external, which windows recognizes but will not load to. I installed the external onto either of the two ports but cannot get the cpu to recognize at all.
  • Robin Vaughan
    Robin Vaughan Dec 18, 2014
    As you can boot from the disc, have you tried to use the Windows repair function?
  • 29 Answers
Try booting in safe mode first.
Start your PC and as soon as it starts, keep pressing the F8 key continuously. If a screen comes up with an option to start in safe mode, go to that option. If you can boot to that option, go to start-type in system and look for system restore. Click on that and follow the instructions.
If you can't do that then look here:
http://www.tomshardware.co.uk/faq/id-1945283/tutorial-fix-bootmgr-missing-error.html
Posted on Dec 10, 2014
Testimonial: "I have utilzed all the above metioned methods but none work. Yes it booted to safe mode, but only if i had the windows install disk in. When propted for a system recovery it was unable to complete. Same was said for the command prompt method as well. I tried to bypass the recovery all together and just reinstall an entire new os, but the cpu wont recognize any hdd to partition to when I do."
Hp g50 laptop
f it will go to BIOS screen, the motherboard would appear to be OK. What happens when you boot from your OS disc and select repair?
Feb 13, 2014 | Computers & Internet
Deleted partition on asus eee pc900
If you set the bios to boot from USB. Place your USB Bootable stick into the USB socket and boot from it.
Windows will find the hdd and format it before putting Windows on it.
What has happened is the hdd name is missing from the system and it requires initializing before you can see it.
Jan 20, 2014 | ASUS Eee PC 900 Notebook
Asus g50 vt-x5 will not POST or boot
Have you tried connecting it with another display?
Jan 06, 2013 | ASUS G50V-A2 15.4IN Notebook
Asus eee pc not booting
Try to go to BIOS and run a HDD test.
To Go to BIOS turn on the NoteBook and Keep Pressing F2 and you will enter the BIOS set up.
Search for Hard Drive Test Option from the Menus
If the Test Passes then you need to Reload the Windows OS or if the Test Fails you need to get a New HDD
Jul 14, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My laptop wont go past the windows loading bar it goes by 2 times then stops on the third one then restarts. what do i do to fix this?
Try running a Boot disc, like Hiren's Boot disk and go to Mini Windows XP and see if it locks up, if not then prolly have to reload the OS again do a repair install to fix it, more than likely a corrupted sys file, and if it does lock up prolly a internal issue, check your HDD/Memory/CPU cooling Fan may be full of dust, blow it out thre the cooling slots on the side with Canned air or Air hose at 60PSI to prevent fan blades from breaking. Hope this helps.
Feb 27, 2011 | ASUS A7J PC Notebook
Lenovo SL 500 not booting after startup only black screen with cursor is seen
Dude,
Most of the time, the machine booting with the blinking cursor indicates a problem with the HDD itself.
You can do the following:
1) Reseat the HDD
2) Check BIOS boot order and see if the HDD is still recognized at BIOS level
3) Load the BIOS defaults (F1 at boot, then F9, F10)
4) If the HDD is detected at BIOS, try to access Rescue and Recovery on the HDD (F11 key at boot) and try to reload Windows.
5) If problems persist, I'd highly recommend replacing the HDD!!
Apr 17, 2010 | Lenovo ThinkPad SL500 Notebook
Set-up recognize my hdd but windows doesn't
Windows uses NTFS file system.
you need to enter a boot disk/recovery disk/windows xp disk into your CD drive and in the system BIOS select the CD drive to boot first. Once the CD has loaded you can re-format your HDD to NTFS and re-install windows
You will, however loose all your data but your HDD will function again with windows
Oct 05, 2009 | Maxtor Hard Drive
Hard drive compressed/bootmgr compressed
U DONT NEED A RECOVERY DISC TO FORMAT YOUR HDD ALL U NEED IS THE WINDOWS DISC U WILL USE TO LOAD WINDOWS THAN START YOUR COMPUTER UP BUT WITH YOUR CD ROM TO BOOT UP FIRST U WILL THAN HAVE TO VERIFY IF U WANT TO UPGRADE YOUR SYSTEM WILL CHECK IF WINDOWS WAS INSTALLED BEFORE AND ASK U DO U WANT TO FORMAT AND YOU WILL SPECIFY YES DELETING ANY OTHER PATITIONS
Feb 06, 2009 | Advent 4211c Notebook
Computer won't boot
when u power up the omputer press F8 key then go to safe mode.
then type in run "chkdsk /r"
then press "y"
then restart then it fixes error on hdd.
Jan 05, 2009 | Gateway M350 Notebook
No drive detected
hey koko
can you try to restart your laptop and try to go into BIOS..
press delete when your laptop is starting up.
when your already in BIOS, look for the booting sequence. you must determine that your harddrive is recognized at this point and make it a primary boot.
post back for any more questions ok.
Apr 09, 2008 | Dell Inspiron E1705, Intel Core 2 Duo...
Computers & Internet Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
