Question about Vizio L32 32 in. LCD HDTV
How do I get a hard copy Model:D320-B1 or B@
Ihave tried to down load on internet with no luck. I will pay to get a hard copy
Why isn't there a mac driver for the Canon imageclass d320? It is such a great machine I don't understand why canon is ignoring the mac market. Last time I checked Mac was now the predominant computer...
I am sorry to say that this model "Canon ImageClass D320 doesn't support Mac Operating System. There's nothing more that I can say about this model.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | Canon imageCLASS D320 Laser Printer
How do I down load to an external drive and not the main computer
1. First, you need to select the external drive while saving any game.
2. Try to play it from External drive first, if game does not play from external drive then try to play it from the Internal drive.
3. It does not make any difference whether you are playing game from external or interna drive because both the drives will use the computer resources and softwares to play the games.
Good Luck.
Mar 23, 2010 | Computers & Internet
I have a black solid streak on my Canon D320 copies
Change the OPC drum cleaning blade and clean used the vacuum cleaner the development station.
Dec 01, 2009 | Canon imageCLASS D320 Digital Copier
Hi i have anti virus pro 2010 on my computer i have tried to remove through my task manager but it has shut down my administrator ihave tried to delete through comand prompt ihave tried file search to...
Go to your control panel and then go to programs. In your programs delete the programs that you want. Go through the control panel then programs to delete a program not task manager. Task manager only cancels the program use at that time it does not delete.
Oct 18, 2009 | Computers & Internet
Driver won't load for canon d320
you will have to download another driver from canon's website here is the link http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=164&modelid=9036#DownloadDetailAct go here an where it says Select OS select windows vista x64 then download the driver and install it. I hope this solves your problem.
May 06, 2009 | Canon D320 imageCLASS Digital Copier
Canonimageclass D320 makes smudged copies. What do I do?
This model is noted for a jam in the fuser area around the roller, Not easy to get to but sounds a like that may be proble, Can you hear a sound like paper wrinking as it runs. Also is the drum in the cartridge clean or has tone on it. Have you changed the cartridge. I do get a kick out of Staples Experts.. They did sell you some cleaning sheets... Hey Good Luck....
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
How do I scan on my canon D320
While the D320 has a scanner, it is used only for making copies. You can connect the D320 to a computer and use it as a printer, but there is no provision for scanning documents to a computer.
Nov 07, 2008 | Canon imageCLASS D320 Digital Copier
Manual required C4280
Hi Go to www.hp.com enter model number into search box, follow links through to manuals, check its the one you require, if so download
Nov 03, 2008 | HP Photosmart C4280 Aio Printer
Laptop hard drive
If you have reinstalled windows, on this hardrive using a different computer, it would not load into windows on the nortino 6770, because the windows now has the settings compatible with the other computer not this machine.
To get around this problem, you would have to reinstall windows, by placing the haddrive in the 6770 only. To do this , you can either copy the contents of the windows cd , to a flash drive or pen drive ,and then connect the same to the USB port of the laptop.
The other way , is connect an external USB cd drive and install the same.
Best of luck
Proton
Oct 11, 2008 | Balance CN6555 Notebook
Vizio L32 32 in. LCD HDTV Logo
37 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
