Question about Refrigerators
I have a Cenco bcd 60 12/240v fridge/freezer. It runs but temp goes up and down. Exterior temp is constant at 20c. It will not reach -18 or stay frozen any minus temp setting. but runs fine if set at 3c or 4c.
    Novelist:
  • 187 Answers
It is my experience from what get from your description, it is one of two things. Low air flow in evaporator and/or low charge.
Low air flow can be caused by a few things. Things to check
1. evaporator fan is working
2. good air flow into and out of evaporator vents
3. Shelves are not over stuffed with product. Air has to circulate in order to freeze items properly and same for cooling in the fresh food section.
If these all check satisfactory, The next thing to check is the condenser coils for excessive air blockage and condensing fan working. A dirty condensing coil can cause everything you describe.
If these all check out ok, then and only then would I check the charge. The compressor discharge temperature during normal operation in most homes will have a surface temp aroung 140 degrees or higher. If the compressor discharge (high pressure) is not hot to touch, (careful if overcharged or dirty condenser the discharge pipe can cause burns.) then the unit is undercharged and needs refrigerant added. Also, if refrigerant is low, a leak search needs to be performed to locate potential leaks.
Hope this helps
Posted on Dec 14, 2014
  • Matthew Garris Dec 15, 2014
    Inside is like new. Fan is 100%. No dust dirt etc. Sprayed soapy water to be sure of no leaks around condenser and pipes. This unit has a battery saving option low, medium and high. I have always have it set on low. I tried switching it to high. No difference. I now think this may be faulty. I believe the battery saving mode may be "stuck on" so the unit only runs in short intervals instead of constantly, to save power.
3 Suggested Answers
  • 2920 Answers
SOURCE: Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Posted on Jan 12, 2009
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Thermocouple
Does it ever actually reach the temp set? It may just need cleaning and a service so it cuts out at the right temp.
Apr 01, 2014 | Engel Freezers
We just bought the house so we are not used to this. Could it be in defrost mode. The freezer is ok but as said the temp goes up a degree and now at 20c
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 02, 2010 | Frigidaire FRS-26DR7D Side by Side...
What setting should I keep my freezer and refrigerator
use a freezer thermometer -18/20C for the freezer and +2/5 for the fridge,are the most economical settings.
Apr 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
What is a reasonable temp setting for this freezer? Bought it without the manual. A quick version on how to set that temp would be helpful. Thx, m..
freezers should be -18/20C to keep beef for 12 months,use a freezer guage in centre of freezer,that way you wont get ice bricks instead of ice cream.....test after 24 hours of setting....
Apr 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I have an amana refrigerator w side by side with freezer at the bottom.what is the best temperatur settinfg is most economical for this type refrigerator?
if you have a fridge/freezer thermometer great.leave inside each one for at least 12 hours to get average temperatures if in use. Answer .. the optimum temp for the freezer is -18/20c.0f, for the freezer and +2/5c.34/36f for the fridge.
Mar 10, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My fridge is a hotpoint a fridge freezer after sitting in the garage for a while the freezer is working but the fridge is not what do i need to do
fist check the temperature of fridge,should be +2-+5c.
freezer should be between -18 to -20c.it is possible that you f/f was designed to operate between +10 to +35 degrees.most are, so as you say its in your garage/shed the ambient temp is too low for it to operate efficiently,hence fridge feels warm(compared to when it was indoors.mine is in shed with a greenhouse heater.kept at +9.....
Feb 24, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
