Question about Toshiba Office Equipment & Supplies
How do i fix my Toshiba studio 202s,double image problem
Replace drum,uhr
  • 3 Answers
Also check your upper fuser roller.
may be worn out
Posted on Jan 28, 2015
    Scholar:
  • 60 Answers
Drum cleaning blade may need replacing/servicing.
Posted on Dec 10, 2014
How to go sarvice mode Toshiba e studio 202s printer
To enter service mode:
Press "Clear => Density select => Clear => Density select.
To cancel the service mode, press the "Clear" key.
Jul 12, 2016 | Toshiba Office Equipment & Supplies
How do i fix my toshiba studio 202s,double image result
If you have replaced all that, check your drum cleaning blade and your erase lamps, these two items will contribute for Ghost images "double image". The erase lamps disperse the electrical charge so the blade can scrap the toner off the drum.
Dec 10, 2014 | Toshiba Office Equipment & Supplies
Blinking panel indicator
toshiba e studio 181 control panel light blinking
Mar 13, 2014 | Toshiba e-Studio 181 Digital Copier
Error code f5
F5 Content Copy lamp lighting abnormality
Detail The copy lamp does not turn on.
Cause Copy lamp abnormality
Copy lamp harness abnormality
CCD PWB harness abnormality.
Check
and
remedy
Use SIM 5-3 to check the copy lamp
operations.
When the copy lamp lights up.
Check the harness and the connector between
the CCD unit and the MCU PWB.
When the copy lamp does not light up.
the copy lamp unit and the MCU PWB.
Replace the copy lamp unit.
Replace the MCU PWB. "
Feb 22, 2013 | Toshiba E-Studio 202S Digital Copier
How to reset maintnance counter
Enter 08-252, clear the value to "0".
08-251, set the value of PM counter.
Jun 25, 2012 | Toshiba E-Studio 202S Digital Copier
Double imaging on toshiba 550 what is the most probable cause?
there could be two main reasons for double imaging
1) contaminated upper hot roller {replace}
2) worn drum cleaning blade {replace}
hope that has narrowed down your problem
Mar 31, 2011 | Toshiba E-STUDIO 550 Copier
C46 appeared on my toshiba e-studio 550 copier
C46 indicates Abnormal pressure roller thermistor during a ready state.
Perform following inspection:
1.. Clear the status counter.
Change the current status counter value (08-400) “3” or “8” to “0”.
If happen again, perform following inspection:
1. Check the pressure roller thermistor.
(1) Check if the connector is not disconnected.
(2) Check if the pressure roller thermistor closely touches the surface of the pressure roller.
(3) Check if the harness of the pressure roller thermistor is not open-circuited.
2. Check the LGC board.
(1) Check if the connector J334 is not disconnected.
(2) Check if the conductor pattern on the LGC board is not short- or open-circuited.
(3) Replace the LGC board.
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
Getting double images on copies, how can I fix?
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Mar 04, 2009 | Sharp AL-1642CS Copier
69 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
