Question about 1982 82 Chevrolet El Camino Instrument Cluster Bulb-1982 Chevrolet In
82 el camino 229 eng no pulse to carb no check eng light key on not running.scanner saeys no link how do i fix this? joe
Just bought car new cap rotor wires plugs got it running expected to get trouble codes jumped a+b termenals no light
    Scholar:
  • 94 Answers
It is always one of three things, fuel, electricity, or air. Check the easy stuff first. Do you have gas to the carb, is the air filter clean, is the battery good, are all the fuses that control the engine good or are any fusible links blown, any bad relays. Could have a bad distributor or it could be out of time if you are getting power to the plugs. Might be worth going to your trusted mechanic and spend the few bucks to run the diagnostics on a real machine, just not one that reads the odb codes.
Posted on Dec 10, 2014
1985 el Camino 305 Rough Idle and Automatic Choke out
If electric choke not working and blade on carb is not fully opened, that would cause your issue...check for power at choke stat, if not, check fuse
Mar 25, 2014 | 1985 Chevrolet El Camino
Runs rough at idle when i drive it runs fine until i come to red light then it wants to stall. if it is idling it will stall to just bought it havent did any maintenance yet
Those El Caminos are nice. If you haven't done any maintenance, I would make sure that the oil is full, check and replace any bad carb. vacuum lines, check for any fuel, intake, vacuum, etc. leaks. Maybe check and replace spark plugs, wires, dist. cap + rotor, also check timing, etc. Good luck.
Nov 20, 2010 | 1983 Chevrolet El Camino
My brake pedal pulses when i apply the brakes on my 86 el camino
Have the front brake rotors turned,or replaced,they are warped .If this was helpful,please let us know,thank you.
Jan 03, 2010 | 1986 Chevrolet El Camino
1982 el camino 305 4 brl has just developed backfiring @ carb , ran great after tune up but still had backfire @high speed . It now backfires @ low speed. Could it be timing belt? \ 131,000 miles w/ 400...
the timing maybe off but it could be a miss adjusted carb. there is no timing belt it is a chau=in and that is most likely not the problem. timing is corrected at the distubtor. but i would check the carb it may be dupming to much fuel
Dec 28, 2009 | 1982 Chevrolet El Camino
Want to replace a dash pad in 82 el camino need instructions to complete the installation
If you've never done a dash pad replacement before I would suggest getting an aftermarket cover77 88 EL CAMINO/MONTE CARLO FULLFACE NEW Dash Pad CAP, $87.99 ... (1) (Made 3 Ways) Sellers Choice New Dash Pad Cap for A 1977 1978 1979 1980 1981 1982 1983 ...
www.onlineauction.com/index.php?page=auction:view...
This is a snap on cover that covers your old one without it's removal,just paint it to match.Now you can get these from a lot of different places and I'm NOT recommending any business or company,just saying this is an easy way to get a nice looking dash without replacing it.
Oct 11, 2009 | 1982 Chevrolet El Camino
How to remove 82 chev el camino brake rotor
Remove the front wheel, use a flat head to take of the dust cap in the center of the rotor. There will be a big nut with a cotter pin going through it. Remove the pin and the take the nut off. After removing the caliper you will be able to remove the rotor and the bearings inside.
Oct 04, 2009 | 1982 Chevrolet El Camino
Hi low hiead light switch 82 el camino wher does the rod hook up
should be a switch mounted to the top lower steering column that the rod fits into that operates the high/low beams
Dec 28, 2008 | 1982 Chevrolet El Camino
1982 82 Chevrolet El Camino Instrument Cluster Bulb-1982 Chevrolet In Logo
62 people viewed this question
Top GE Vehicle Parts & Accessories Experts
ray012965
ray gallant
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
