Question about Ryobi Garden
Install recoil spring on RYOBI08420
Spring came apart when I went to install new rope
  • Ryobi Master
  • 1,169 Answers
Requires the removal of the engine/starter cover so you can rewind the spring as you will need to get it back in place.
Once you make sure the spring isn't broken or badly bent and installed correctly, you will wind it up until it stops and back off one turn and install your pull rope.
If the spring is damaged then it is best to replace it as it will give problems.
Posted on Dec 10, 2014
How do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Jan 12, 2015 | Electrical Supplies
Recoil spring problem
I have the same chainsaw and have never had a problem with it.
If you have changed the starter rope or recoil spring in the past, it is important that you hold the new spring with needle nose pliers and install it correctly. Once the spring is in make sure wind the rope correctly-clockwise. If not the new spring will be damaged.
Sep 14, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
How does the recoil spring,waher,2 hairpins pins,dog footand rope pulley get reassembeled?
the rope rotor will go on first, then the washer goes on, put the dogs in then put the spring on. insert the rope into the rotor, wind it up, feed the rope through the starter cover, carefully allow the rotor to wind in the rope a ways then put the handle on.
Dec 20, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Replaced pull cord on craftsman push mower but wont retract back like its's been pulled all the way out it's all slack. What do i need to do to get it to spring back? It's 5.5hp self propelled mower about...
if you get this the first time get a lottery ticket fast.
take the recoil off and apart, check to see if the spring end is broken off. (sometimes you can bend a new hook into it but it will usually break because its hardened).
buy the way, Usually you can wind a rope around what the recoil connects to, to start the engine at this point.
take the handle off the end of the rope and wind it around the drum/spool leaving a few inches hanging out.
hook both ends of the spring to their stops and wind the spring tighter about four turns, then thread the end of the rope through the hole and pull on the rope and test the recoil. Don't lt it go.
pull the rope out and put a "marline hitch" in it or use a visegrip pliers to hold the rope out and tie the handle back on.
replace recoil.
if the rope looks fuzzy most all hardware stores have it.
good luck
Apr 29, 2011 | Garden
The recoil spring on my 1986 victa lawn mower will not rewind the starter cord. Is this easy to fix?
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assembly. Depending on engine model you may have to remove the air shroud with the recoil.
- Remove the broken rope assembly from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rope burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assembly.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 03, 2010 | Briggs & Stratton Garden
How do I replace the pull rope on my bl100 trimmer? I know how to install it just not how to get it to rewind.
You are going to need to "preload" the spring in your recoil/starter unit BEFORE you install the pull rope. Turn in in the direction where you feel it becoming tighter. Turn it about 5-7 revolutions. Don't get carried away and make it REAL tight as you will break the spring steel recoil spring. After you have it set, jam it or hold it with vise grips or a screwdriver or with your hands and have someone install the pull rope. Make sure the handle is installed on the end of the pull rope before you begin because when you let the recoil pull your new rope in the handle will stop it. There should be a little bit of tension left on the pull rope once it is drawn in all the way.
Oct 31, 2010 | Garden
Broken rop on weedeater gas trimmer
There is a spring under the starter spool, the one with the rope on it, leave the spring ALONE, Just take the spool and replace the rope as it is. You take the spool off, put the new rope on the spool, place the spool onto the spring and by holding one end of the rope straight up in one of the slots on the spool, go as many times as you can. When you have it as tight as it can go, hold your thumb down on the spool. Insert the rope through the hole available, grab the rope on the other side of the hole, (outside the casing). Hold the rope and S-L-O-W-L-Y allow the rope to retract. If it finishes before the rope runs out, pull on the rope and install the handle. If it tries to go beyond, hold the rope and install the handle there. Hope you have luck. Remember, leave the spring alone...Lee
Jul 23, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
90 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
