Question about Car Audio & Video
I have a cassette stuck
Nothing
    Novelist:
  • 135 Answers
Generally when a cassette gets stuck the take-up spindle is not doing its job and the tape wraps around the capstan with a gradual increase of the audio pitch. No easy way to get it out with the tape intact without removing the player and opening it up and carefully winding the capstan backwards until it comes free. The real problem is the take-up spindle belt is probably stretched and slips meaning this will likely happen again unless the belt is replaced. Google cassette belts for parts suppliers.
Posted on Dec 10, 2014
Cd is stuck in 6 cd changer nothing works to get it out
hi.
there should be a small hole just around the outside of the CD cassette.
a paperclip, or similar in this hole will operate the manual release for the cassette.
you should then be able to work the cassette out gently. if the cd is jammed any furter into the machine, then you may have to dismantle the entire player to remove the cd.
hope this helps
Jul 22, 2011 | 2006 Honda Accord
Cannot eject cassette
Remove power source/ battery from camera for couple of minutes, replug/ attach battery and check.
If camcorder still gives error then its mechanical issue in tape mechanism and qualified camera tech will repair it.
Thanks.
Aug 31, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Color ink cassette stuck in canon selphy
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Jul 08, 2009 | Canon SELPHY CP740 InkJet Photo Printer
Sony slv-960 VCR cassette stuck inside
As your "free service" is not free I solved the problem by throwing the item into the trash.
Jun 25, 2009 | Sony SLV-675HF VCR
Aj-d200 video camera, cassette door stuck partially open. best diagnosis and/or remedy?
Partially open sounds like a mechanical problem with the cassette housing/door assembly. The door usually stays fully open or will not open at all, caused by component failure on the mechanical driver board. Check to make sure nothing is stuck in the mechanism, like a label or a broken piece from a cassette. If the door will move, but will not latch closed, the problem is most likely on th emechanical driver board.
Mar 25, 2009 | Panasonic AJ-D200 Camcorder
'99 Mercurary Tracer cassette player problems...
The cassette adapters are notorious for getting stuck in the deck. More often than not its the wire that comes out of it that causes it. The cleanest and safest way to remove the cassette adapter is to remove the radio, take off the top and "Help" it eject with your fingers or some narrow tool that may get behind it to push it forward and out. If you dont want to take the deck out of the dash, you can try pushing the eject button while manipulating the adapter wire, but I dont recommend it. Its just better to take the deck out. Good Luck
Feb 06, 2009 | Car Audio & Video
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
