Question about Cameras
How do i make the card write protected go away
When i try to take a picture i get the error card write protected. i have changed the sd card, turned the camera off and nothing is working,
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Dec 10, 2014
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. what i do?pls explain with pictures
If the memory card is a SD memory card then
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 22, 2013 | Sony Cybershot DSCW310 Digital Camera
Tip
How to Unlock SD Card
<p>Many times people do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the <span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the changes that you want to make or download anything from it.<br /> <p><br /> <br /> <p><span style="font-weight: bold;">To allow the SD card to be accessed</span> is a simple as sliding a small tab on the side of the card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab towards the back of the card and away from the front of the card. The card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do this.<br /> <p><br /> <br /> <p>Here is a <span style="font-weight: bold;">picture of an SD Card</span> and you can see the tab on the side of the card. It clearly shows you what is the locked and unlocked positions on the card.<br /> <p><br /> <br /> <p><img src="heatman101_2.jpg" /><br /> <br /> <p><br /> <br /> <p>This feature can be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data or pictures</span> from the card. If you have children viewing pictures on the SD Card make sure to lock it before allowing them to play around to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br /> <p><br /> <br /> <p>As you can see this is a very good feature to have and it will be very useful to you, but you do need to remember to unlock it before trying to make changes to the card.<br />
on Apr 21, 2011 | Cameras
When i turn on the camera it says xD Write Protect.
It can be that if you have a SD card in it you might have somehow clicked the protect small lever. if so take out the SD card and check the sides of it and see if you find a small square like lever then try sliding it up or down however it will go. My SD card has it and when I sometimes put my camera away I slide it to write protect mode so that if my kids somehow get a hold of my camera and play with it they wont erase my pictures. Then when I need to use it I slide it back to unprotected mode. Hope that is your problem.
Aug 08, 2011 | Olympus Stylus 720 SW Digital Camera
When I turn on my camera I get a msg saying " Memory Card is protected (Reset switch on memory card)" Ummm what!!! I can't get this msg to go away, and now I cant take pictures. At the bottom of the screen...
Most SD cards have a little plastic switch, However if you using a SD adapter it might not be fully reading the adapter witch causes this error or the camera is defective.
So if at one point things where hunky Dory and now its saying this try another memory card and if that does not work then the camera is the issue.
Oct 02, 2010 | Kodak Cameras
I have a JVC 20 GB camcorder. Model GZ-MG2-1U. Before I tried to install an 8MB SD I selected on the menu to protect all. I turned the camera off, installed the SD card, turned the power on and then I...
There should not be anything to install when inserting an SD card, all you do is put the card in the card slot. If you tell it to format you have to go into the menu first and tell the camera which you are referring to the card or the harddrive. If you didnt change the setting to SD card when you did give it the format command than that is why your data was lost. If you are having an SD card error make sure that the little slide switch on the card is set as not to protect the card that will give the error sometimes. I hope this helps
Sep 15, 2010 | JVC Video Cameras
My sd card on my camera now says write protected...
Look for a small switch on the side. Switch away from the locked position.
May 20, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Feb 08, 2010 | Kodak Easyshare C813 Digital Camera
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Cant copy pictures to sd card error msg write protected, help!!!
    Look at the tab on the sd card to be sure it is not in the locked position. Thats probably it or you need a new sd card.....
    Apr 16, 2009 | Palm Treo 700wx Smartphone
    Turn off card protection
    The SD card has a small "lock" slide switch on its side. Simply slide it away from the contacts edge.
    Saul.
    Jan 11, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
    Cameras Logo
    41 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
