Question about Heavy Duty Arrow T50 Staple Gun
My T50 abruptly stopped working. When you squeeze the handle, it just goes down easily, nothing happens. Checked, no jamming.
Checked for jamming. Removed front part, clothespin type spring looked off, got it back together, then would not go down at all when squeezed. Is there a trick to reassembling it?
Getting BL error even when the lever is down. I wiggle the lever and goes a little and jams.
the machine needs to be checked to see why the problem is happening
Apr 14, 2016 | Sewing Machines
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Bought an older evenflo comfortflow stroller. Can't figure out how to break it down. Printed on handle: pull up, squeeze, push down. Nothing happens.
I own one also. I think the button gives out over time but don't worry it still folds. Look at the front of the stroller like your putting a kid in you will notice two handles one on each side, there are buttons on both and they jam sometimes, push the buttons in an pick up at the same time and it will fold.
Sep 13, 2009 | Evenflo Baby Gear
Which bolt is the Fill Plug? Is it also a T50
the plug on the left side of the transmission is the transmission fluid. The plug on the right is for the SMG fluid
Sep 09, 2009 | 2004 BMW 3 Series
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
My NAD M3 amplifier stops working abruptly.
If NAD doesnt respond , find a decent amp/stereo tech in your area.
I can suggest some depending on where you are.
There's most likely a component failure that regular folks wont be able to fix
Dec 21, 2008 | Audio Players & Recorders
Just stopped heating
Unless you have a 5 or 6 hundred dollar iron, there is an excellent rule of thumb when an iron quits working. Buy a new one. These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Oct 04, 2008 | Toastmaster 3302 Iron
Paper Jam Error
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 14, 2007 | Canon PIXMA iP1600 Printer
Heavy Duty Arrow T50  Staple Gun Logo
154 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Joseph Hoffmann
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
