Question about Cell Phones
Lanzar sdbt73n screen works but doesn't respond when u touch... Can't change stations or change songs on disc.. Just has a cross I center of blue screen
    Master:
  • 755 Answers
This could be the setup , put your finger on the cross then the next one and so on , this could just be a setup feature
Posted on Dec 10, 2014
4 Suggested Answers
  • 21 Answers
SOURCE: the touch screen on my
you can contact the service provider........
Posted on Jul 27, 2011
muhammada101
  • 70 Answers
SOURCE: touch screen doesn't respond when i try to unlock screen
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Aug 04, 2012
thusith_bc
SOURCE: my nokia 5230 touch is not working,if I press the screen it doesnt respond
It could be the Digitizer malfunction.You can order a Digitizer from Ebay for around 4-5$ with tools.So easy to install even..12_19_2012_5_52_19_am.jpg
Posted on Dec 19, 2012
Having a problem with the touch screen with my Roland E80 keyboard work station. Very slow or no change . Please help .
Open up the Roland E-80 and check if all connectors and flatcables are well seated.
Dec 21, 2016 | Roland Music
Lanzar SDBT73N the preamp output dont wotk on my equalizer. But if i connect direct to the amp it work perfect...
equalizers have a tape loop type input/output, there is a button to push that sends either the processed , or unprocessed signal through, check your connections again, power everything back up, and look for that button.
Oct 17, 2013 | Audio Players & Recorders
I have the Sharper Image m18a android tablet and everytime i touch the screen there comes some blue cross that draws a short line and there are some columns in the top of the screen conected to that i
In my tablet, in settings, under 'Developer Options' in 'User Interface' there is 'Pointer Location' which is a screen overlay which shows current touch data. To me what you are seeing sounds exactly like this function when it is selected. Hope this is the answer you need.
Jan 14, 2013 | Nextbook Tablets & eReaders
My lanzar sdbt73n just all of a sudden stopped reading all disc. I need help
lanzar sdbt73n stop working. on the face plate the power button dont work. only way to turn on is using the remote. once turn on nothing works i.e. power, mute, open (for screen). the only thing that works is the volume knob. i have pushed the reset button but still the same.T73N S DefsdBT73
Jun 19, 2011 | Lanzar Sdbt73n Car Video Player
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
I have a designer 1 and when i select the option block that I want - i actually have to touch below it a whole block for it to register what I wanted!! Help!! We moved states away from where I bought it.
Do you mean that you can't select a stitch except by touching below that stitch instead of on it? If yes, then you need to re-calibrate your screen. It's easy! You should use your stylus for this, but if you have lost it use the blunt end of a machine needle instead.
Go into your SET menu, hit More twice - or until you see "Color Touch Screen Adjust" (it might depend on what version machine software you have loaded just which screen it is on). Click on this. (Keep touching below and around the button until you get it to respond.) Touch in the CENTER of cross 1 (upper left corner of screen). When the cross changes from black to green, the point is set. Do the same with cross 2 (lower right). Done!
Just be sure to touch ONLY THE CROSSES on that screen, except for OK when you are done.
Nov 29, 2009 | Husqvarna Designer I
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
Leapster doesn,t respond when the pen touch screen
for leaster 2 -
turn off unit, take out cartridge.
hold the hint button, turn unit on.
press A button, touch the stylus on all the cross hairs that appear.
power unit off when done.
power back up.
(got these from the leapfrog site and it worked for me!)
Sep 29, 2008 | LeapFrog Leapster Electronic Book:...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
