Question about Air Tools & Compressors
So I have a senco gas framing nailer and it doesn't fire it seems to me that the saftey isn't catching or somethjng because I can push it against some wood the fan comes on and I can smell the gas but It won't fire also when I push it against the wood the chamber that holds the gas in the old pops open everytime but closes when I let off.... Am I doing something wrong or did something break.... Or does anyone else have this problem?? Every once in a while it will fire if I try to hold that chamber closed....
    Habit-Forming:
  • 103 Answers
Check the battery
Posted on May 19, 2017
techman
  • 3130 Answers
SOURCE: 5 disc tray opens and then shuts
Your problem could be one of three differnt things. It could be that the open close switch on the front has a bit of resistance to it, sand when you press it the switch starts to conduct and then the machine thinks someone has pressed the open/close switch again, or there are a set of small switches inside the unit that the door makes contact with when it reaches the end of the travel lenth, that is binding or broken, or there is a problem with the switch or microprocessor circuitry that is affecting the open close command. The correct repair procedture would to be to get a service manual and trace out these devices that I have just described.
Posted on Oct 07, 2006
  • 3197 Answers
SOURCE: I have a Craftsman 1/3 hp garage door opener which
You have a bad logic board.
Posted on Jun 04, 2009
SOURCE: My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Posted on Jun 19, 2009
  • 15 Answers
SOURCE: My door doesn't seal/catch when closing. Machine
If the door switchmechanism is still in place inside the door, you should be able to see it when you open the door ,it is visible on the inside if the door top centre if it is intact then it could be that the actuator bracket has moved, this is located under the top panel front centre and is held in position by an hexagonal nut. the top is secured at the back of the machine by 2 screws one on the left and one on the right remove the two screws slide the top to the rear approx 1/2 inch lift off the top you can now access the door catch bracket, close the door and adjust the bracket forward so that it latches securely but don't position it to far forward or it could bottom on the back of the door mechanism, if everthing is in place unit should be fixed, reposition top onto the two front lugs and slide top gently forward replace the two screwws at the back and you should be in business
Posted on Apr 29, 2010
Testimonial: "Thank you , we will try this."
  • 760 Answers
SOURCE: I changed the gas cylinder in my paslode framing
Make sure you have the correct gas cylinder. There are more than one type of cylinders for these nailers. If it is not correct it won't seat and gas will leak. Whiring sound is normal, fan mixing oxygen. Make sure "O" ring is in place under the gas cylinder.
Posted on Oct 02, 2010
The trigger on my senco 502 nailer will not compress, ie will not fire. Why and what parts if any do I need.
Check the manual if you have a safety switch. Also check for any bent nails inside the gun. Make sure all is OFF before investigating.
Oct 12, 2016 | Senco 4D0001N Framepro 502 Framing Nailer
Trigger
There is no adjustment that can be made to make the safety work or not. When new, the SCN45 had a safety system that prevents the nailer from firing unless it was pressed against a surface. If your gun fires without the safety being compressed, it has somehow been bypassed either by being jambed or tied in the firing position or the trigger lever is wedged so it can't operate properly. Below is a site that has a great breakdown of your tool that you can reference to see what parts may be missing. This is an older tool and many parts are no longer available.
Senco SCN45 Coil Nailer Parts
Dec 31, 2013 | Senco SCN45 Coil Nailer, Contact or...
Senco 601-at its deepest setting the nail likes a 1/4 inch of being flush. 110-130 psi and oiled good
The tip of the driver could be missing. Easy to check, remove nails from the gun, connect air, then push the nose against rubber hose (scrap airhose) (tilt the gun to side while pushing the nose against hose so that you can see the driver come out) and depress and hold trigger. When you fire the gun the driver should be visable (about 3/16 past nose). If you dont see the driver, then most likely broken at tip. If the driver is visable, then most likely adjusted to high or safety foot bent. Good luck
Aug 03, 2013 | Senco & Frame Pro 601 Framing Nailer
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
What's your problempaslode gun will only fire when pushed down twice before firing?
the saftey switch that is triggered when u pick it up maybe a little sticky or if the switch is through wires then it could be the connection
Jul 10, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
SENCO Framing nailer suddenly decided not to fire. Air escapes from top of gun when trigger is pulled
You have some worn/broken o-rings inside the gun. You need Senco repair kit #YK0360 to fix it. Fairly easy to replace the o-rings, just be sure to put lots of lube on the rings as you put it back together.
Nov 29, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
Senco 701xp, I press to nail and get a air hiss as low nails
the problem is in the safey area of the gun, it could be the safety is only partially pushing in (what is sounds like) also, the track may be dirty and need lubed. Spray WD40 on the track and up the nose.
Also, check the thumbscrew on the back of the track by the handle and make sure the track is pushed all the way forward and tightened up
Jul 11, 2009 | Senco & Frame Pro 702xp Framing Nailer
Air Tools & Compressors Logo
60 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
