Question about Welding Tools
How do I replace the wire - Welding Tools
    Master:
  • 755 Answers
You have manually start it from the spool , pain but this is the way to do it
Posted on Dec 10, 2014
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
I have a gfci/switch and need a 4 wire instructions. As none of the diagrams match what i have.
What device are you replacing... a switch or a outlet?
1) If you are replacing a switch with 3 or 4 wires?
That is either a 3-way switch, 4-way switch, or a DPDT switch and cannot be replaced with GFCI
2) If you are replacing outlet with 4 wires, then it can be replaced with GFCI combo.
http://waterheatertimer.org/How-to-wire-GFCI.html#8
3) If you are replacing ordinary single-pole switch, then you can replace with GFCI combo IF the box has a neutral wire
http://waterheatertimer.org/How-to-wire-GFCI.html#6
4) You can install GFCI protection on any circuit by installing GFCI earlier in the circuit.
http://waterheatertimer.org/Basic-house-wiring.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 21, 2014 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
I have a broken spark plug wire. Can these be replaced?
Steve:
Yes, the spark plug wire can be replaced, but you have to buy the ignition coil as the spark plug wire is hard wired into the ignition coil.
If the metal spark plug connector has disconnected from the spark plug wire, the connector can be replaced, but if the spark plug wire has been cut you'll need to replace the ignition coil.
Nov 29, 2013 | Homelite 200 mph 400 CFM Gas Blower...
What does the blue wire hook to
The blue wire always goes to Load (light fan motor)
If you have Intermatic ST01C or EJ500, see wiring illustration on following page:
http://waterheatertimer.org/ST01C-program.html#ST01C
If this is not your timer, then add a comment.
Wiring is dependent if you are replacing single pole switch or 3-way switch.
For single pole switch replacement:
Old switch has two wires.
Connect these wires to timer blue wire and timer black wire, in either order for now.
Green connects to bare ground wire.
Turn power ON.
Click timer on-off button.
If lights turn ON-and-OFF, then timer is wired correctly.
If lights do not turn ON-and-OFF, then reverse blue and black wires.
Timer red wire is capped off with wire nut
If your lights involuntarily blink after pushing ON-OFF button, then timer red wire is connected where timer blue wire should be connected.
For 3-way switch replacement, there is also a wiring diagram shown on link above.
Keep in mind that ST01C and EJ350 cannot replace a 3-way switch wire-for-wire.
Blue wire must always go to Load.
The other 3-way switch is also wired differently.
Add a comment with careful description of your wire colors and I will respond.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps while you are wiring the device for a price.
Dec 26, 2010 | Intermatic & Self-Adjusting Wall Switch...
What color plug where i ve got three colors blue,red,black
If I understand correctly, you are replacing a switch with the EJ500 timer.
You mention a 'plug'
The EJ500 has 3 wires: Black Red Blue.
If you are replacing a single-pole switch:
The switch has 2 wires, one of these wires is the Hot-from-breaker and the other wire goes to Load:
Timer-black connects to Hot-from-breaker.
Timer-blue connects to wire-going-to-Load.
Timer-red wire is capped off. Red is not used for single pole switch.
If you connect wires and your lights blink, then you put the red wire where the blues wire should go.
If you connect wires and lights do not operate, try reversing the blue and black wires.
I posted images of EJ500 wiring (the Intermatic EJ500 and ST01C have identical wiring
If you are replacing a 3-way switch, the wiring is more complicated.
The EJ500 can not replace a 3-way switch wire-for-wire.
Diagrams on link above show wiring for 3-way.
Add a comment if you need more help.
Nov 10, 2010 | Intermatic EJ500C - Indoor Digital Wall...
Installing a 7 day digital wall timer
Swylite LST100 timer has 4 wires. Red, Blue, Black, White
Timer has more wires than wall switch because timer has electric clock inside. And with + series Swylite timer, it also has led bulb that needs power.
Timer can replace ordinary on-off switch
-On-off switch has 2 screws, so 2 wires (plus ground wire) connect to on-off switch
-Three of the four timer wires are used when replacing on-off switch
-Red wire is not used, it is capped off
Timer can replace 3-way switch
-Three way switch has 3 screws, so 3 wires (plus ground wire) connect to 3-way switch
-One of the screws on 3-way switch is colored dark (it is crucial to identify the wire that comes off dark screw so timer can be wired correctly)
Lets replace on-off switch see diagram
Timer black goes to Hot wire
Timer blue goes to Load (light, fan, motor)
Timer white goes to Neutral
Timer red is capped off.
How to check which wire is Hot, Neutral and Load
Switch you are replacing has 2 wires > one is Hot, the other goes to Load
Remove these two wires. Separate wires so you can test. Turn on power. Tape tester leads to wood sticks so hands are away from power. Test each wire to bare copper wire.
When tester lights up >> that is Hot wire >> please connect this wire to Timer black wire
The other wire goes to Load >> please connect this wire to Timer blue wire.
Now test for Neutral. Test Hot wire to other wires inside box. Neutral should be white. When tester lights up, that is Neutral. Please connect Timer white wire to neutral. IF YOU DO NOT have a neutral, you can connect Timer white to bare ground wire until you have time to drop a Neutral into the box.
Replace a 3-way switch see diagram
Three-way switch has 3 wires.
Identify which wire connects to Dark screw on switch >> and then please connect this wire to Timer Black wire.
Timer white wire connects to Neutral
Timer blue and red wires connect to other two wires that came off switch ... they connect to either one.
Oct 01, 2010 | Solar Ivory Swylite Lst100+ Back-lit...
HOw to replace spark plug wires on a 1998 Mitsubishi montero sport?
Installing New Spark Plug Wires Is Simple, Especially Of One Wire Is Replaced At A Time. Compare The Length Of The Old Wire With The Length Of The New Wire. Replace Each Wire With One Of Equal Length.Make Sure The New Wire Is Fully Attached On The Plug And In The Distributor Or Coil Module.
Spark Plug Wire Replacement Is More Complicated If All The Wires Are Removed At Once.Then You Must Use The Engine Firing Order And Cylinder Numbers To Route Each Wire Correctly.
Apr 09, 2010 | 1998 Mitsubishi Montero Sport
My Alba PRDAB200MP3 player's battery runs out very quickly. can i replace it?
Yes you can, but you can't get a replacement battery. I used a IPod Gen4 replacement battery, which seems to work well. Undo the 2 screws at the bottom and un-clip the top. Cut the wire off the old battery and join to the new as follows - Black wire to Black wire, Red wire to Red wire, White wire to yellow wire and solder and then cover joints with tape. Replace cover - Took me 10mins.
Nov 17, 2009 | Audio Players & Recorders
NEW PLUGS AND WIRES
The correct arrangement?
I always remove one plug wire, replace that spark plug, and then replace that one spark plug wire. This way I never cross which plug wire to which position.
Oct 29, 2009 | 1999 Volkswagen Jetta
the easiest option is to unplug one wire and change that plug, then put the new wire on, repeat for all plugs and wires.
May 08, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
