Question about Refrigerators
Dishwasher problems Water not going in
    Master:
  • 755 Answers
Ck the power going to the pump ,
Posted on Dec 10, 2014
Have a Hotpoint dishwasher DWF33. Supplied with cold water supply from mains. My problem is that water is not heating during operation. Regards, Stephen.
Always supply hot water to the dishwasher...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 10, 2011 | Hotpoint Dishwashers
Tip
Dishwasher Trouble No Water entering Dishwasher
Your dishwasher will not let water into it. So you are wondering what the problem could be? There are usually two reasons for this problem. These two things can easily be explained so that you can find your problem.
The first thing that I am assuming is that you have water going to the dishwasher. Make sure that the problem is no external to the dishwasher before tearing into it and finding out later that you have a water feed problem.
Now that we have that clear, let’s focus on the dishwasher.
Problem #1 is usually the water inlet valve. To get to this valve you need to remove the bottom front access cover of the dishwasher. Behind this in one of the corners (usually) the water hose/pipe will hook to the inlet valve. This valve will have two and sometimes four wires going to it. Some valves will have an inlet screen right where the hose hooks up. Make sure that it is clean. If the valve is getting water and it has a slight buzz when it should be feeding water then the valve is bad. You need to replace it. If there is no current going to the valve then you have other problems and need to trace back the power problem.
The one other problem that is most common would be the float switch. This is a plastic round cylinder usually that rises up as the water level rises. If something happens to get stuck under it you will not be getting power to the inlet valve. If this switch has gone bad and is reading in the full position even though it is not, then you will have to replace that.
The inlet valve and the float switch are the most common problems for not getting water to your dishwasher. By finding out which is the problem you can easily fix your dishwasher and be going again.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Jan 31, 2010 | Dishwashers
No water going into to dishwasher all of the sudden.
check water connection to bottom of dishwasher (left hand side) if you have water going into the valve but no water coming out of the valve theres the problem check to also see that you have power to the valve
Apr 29, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
When I start my dishwasher water wont go into the dishwasher.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jul 18, 2009 | Dishwashers
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
Water doesn't run in to clean dishes
if the water line not blocked or pinched... then I would your fill valve.. it may not open all the way...before replaceing the water valve...check that the water is come into the dishwasher but maybe going out the drain..If the drain hose is too low water will run out before the dishwasher can run a cycle... to check it it must raise above the bottom of the sink ... this keeps water from running out and sink water from going into the dishwasher... let me know if it helps
Jan 29, 2009 | GE 24 in. PDW7880JSS Built-in Dishwasher
Kenmore dishwasher keaving residue
the problem is not the dishwasher but the water that actually is going into it. the white, powder substance is because of hard water. there is a affordable product out there called the dishwasher filtration system. it will filter the water going into your dishwasher and solve the problem once and for all!!! it is affordable and easy to install. www.dishwasherfilter.com
Jun 05, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Chalky dishes in dishwasher
Jan 16, 2008 | Maytag MDB7100AWB Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
My Asko D3330 dishwasher won't load water
Since your dishwasher is under warranty you should contact to the appropriate factory service center for repair your problem !!!!!
Aug 28, 2007 | Asko 24 in. D3350 Dishwasher
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
