Question about Westinghouse Televison & Video
How do we get into service mode to flip picture
New main board installed. Need to invert picture right side up.
    Top Expert:
  • Westinghouse Master
  • 75,304 Answers
Answered a few while ago.
Posted on Dec 10, 2014
I was changing mother panel and now the picture is up side down.i need factory setting code is it possible?
if it is a SAMSUNG they use the same main boards from 40" to 70"... and what you need to do is get into SERVICE MODE then select CONTRO and look for HV FLIP in not there go back and SELECT on the OPTION it will then show the TV size.. push left or right on your remote until your correct TV size pops up then press return. Now turn off the TV. Turn it on and presto. Done. To get into SERVICE MODE tv must be off. Press mute 1-8-2 then power or press info., menu, mute then power.. remember tv must be off. Let me know if this works or if you need further assistance
Aug 22, 2017 | Televison & Video
I replaced the main board and power board on my Vizio P602ui-B3. Everything works now but I have the left side of the picture is darker than the right.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 06, 2017 | Vizio Televison & Video
32in LG TV. Sound but no picture. Flashlight test = picture. Ordered a new power supply board. Installed it & TV will not power on now. Put the old board back in & it will not power on.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 28, 2017 | LG Televison & Video
Right have of led tv is darker
Nov 13, 2016 | Samsung Televison & Video
Sharp TV model LC-70LE650U Dark on Right side
http://electro-medical.blogspot.com/
Jan 27, 2016 | Sharp Televison & Video
My Phillips 47pfl7603d/10 is dislays a dimmed screen and sometimes a flipped negative image on the right side. This happens 2m-40mins after turning on. Contrast=60 brightness=0 Colour=60
Oct 19, 2015 | Televison & Video
Vo42l no picture. please help!
I had the same problem. No picture but sound. When I turned on the tv, and shined a flashlight around the screen from about 3 inches away, I could it was displaying something.
At first I replaced the main board which has 0171-2272-2604 stamped on it. You can google Vizio VO42L service manual and get a pdf which will show how to remove the back. I got the board from TSM www.tristatemodule.com3642-0482-0150 3642-0482-0150 Vizio TV Module, main unit, 0171-2272-2604, 3642-0482-0395, VO42LFHDTV10A 1 $88.95 $88.95
Order Notes: None
SubTotal:
$88.95 Shipping: USPS Priority $20.00 Tax:
$0.00 Total:
$108.95 However, after I replaced this board I still had the same problem. So next I replaced the Invertor boards. There is a Master and a Slave board to the right and left sides of the main board. I ordered these from Coppell tv.
on Ebay.
6632L-0470A & 6632L-0471A INVERTER REPLACEMENT SET - NEW, OEM, WARRANTY ( 110882329800 ) 110882329800_1.jpg Paid on Jun-08-12
$49.99 -
$49.99
USPS First Class Package Estimated delivery: June 13, 2012
These are compatible replacement inverter boards and work well. All I had to do was bend a tab on the aluminum cover that goes over the boards. After installing these inverter boards the Vizio display works. I started with main board replacement because from what I read online, the problem was either the mainboard (which had the most posts) or the inverter boards. So I picked one.
Install tips:
Download the PDF Service Manual VO42L FHDTV10A_LPL,AUO Service Manual.pdf for some help with the back cover.
When you take all the screws out, set them aside in the same pattern they were on the board for ease of putting the back in.
I was not able to remove the connector on the Ribbon cable between the master and slave invertor, so I left it attached and carefully undid all the tape and removed the boards attached. I plan to send the old boards to Coppell TV (really nice to work with) for their re-use.
I hope this helps.
Feb 27, 2012 | Vizio VO42L 42 in. LCD TV
Sanyo dp42849 picture is slow
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
I just changed the main power board, and everything is fine...apart from no picture...sound is fine. Before the power board died, the picture was fine, apart from what looked like a water damage mark...
You need to try the following:
Check the power supply caps and voltages. Reseat the ribbon cables between the T-CON board (Timing Control board) which drive the LCD panel rows and columns, it get the LVDS (Low Voltage Differential Signals) form the main board which has the VIDEO processor to drive the T-CON board.
When T-CON is dead you will see glowing screen without video, or when it has timing problem you will see lines, rolling, multiple pictures, pixelating.
The main board supplys switched 12vdc to power the T-CON board.
You need to do more checking.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 14, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
Samsung HLN437W
REPAIR: Enter the service mode; under option menu DDP1010 (DDP1011, where
applicable) adjust the V-Flip option back to normal. If the problem continues
replace the DMD Board
Mar 02, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
