Question about Donic Testra AR Plus
How to take an ar test
Bvhgvdrhdfc
How do i get ar tests answers for free
What sort of printer is an AR.
If it is not a printer then why use this form of media?
Sep 09, 2014 | Office Equipment & Supplies
I cant clear H2 problem on sharp AR-M160 copier machine
"Press # - Interrupt - C - Interrupt -14 - Start key Thermistor open
The thermistor is open. The fusing unit is not installed.
Mar 29, 2012 | Sharp AR-M160 Black and White Copier
Replaced main pwb on sharp ar-235 now i need to program the machine counter data is it a special test command
You need the EEPROM from the old PWB and put it on the new PWB to retain counters.
Sep 30, 2011 | Sharp AR-235 Copier
Sharp ar-m230 code erreur H4.00
The problem is in the fixing assembly. Do the following:-
1. Check if the thermistor is working properly.
2. Check if the fuser lamp is not broken by testing for its continuity.
3. Test for potential difference (voltage) on the terminals for the fuser lamp.
If all these are okey then the code can only be cleared. It has to be done by an expert. I can intruct how to do it but if you are not an expert. you may damage the machine.
Jul 12, 2011 | Sharp AR-M237 Digital Copier
I want to connect my ar-507 gray digital copier to pc UBS port
Did you use a pcl driver? What was the error message?
Nov 19, 2009 | Sharp AR-507 Copier
Printing by SHARP AR M161 on Mac 9.2.2.
Go to printer setup and click on new printer. You should get a long list of printers. Hopefully yours is on the list. Click on the printer name and you will be presented with several drivers. Choose the one that is the best for you. Before you exit print a test page. Give the printer a name.
If this does not work you will have to install the windows driver. This is only possible If your Mac can run windows software.
Mar 04, 2009 | Sharp AR-M162 All-In-One Laser Printer
Error Code F1-00: How to clear on Sharp AR-C250
go into service mode (program interrupt clear interrupt)
enter simulation 26 sub 1 (option setup)
change to no finisher
CA to exit, and you're all set
Dec 11, 2008 | Office Equipment & Supplies
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
Dec 15, 2006 | Sharp AR-C270 Color Copier
Donic Testra AR Plus Logo
Top Donic Sport & Outdoor - Others Experts
Are you a Donic Sport and Outdoor - Other Expert? Answer questions, earn points and help others
