Question about All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
I have tried for better tan 20 minutes to try and fire up my heater and it just wont fire and run. I have spark to the new igniter and can smell propane but it wont begin to fire and run.
    Scholar:
  • 103 Answers
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Posted on Dec 10, 2014
I have a Tecumseh engine on my Troy-bilt snow blower. It starts right up and will run for as long as five minutes and then dies. I have taken off and cleaned out the fuel tank, installed an inline fue
First try running it with fuel cap slightly loosen as the air vent in the cap be plugged creating a vacuum on the tank. If you engine continues to run for 10+ minutes when this is done replace the fuel cap.
Next when the engine dies immediately check for a full fuel bowl if empty or nearly empty then you still have a fuel flow problem.
This can also be an ignition related problem where the electronics in the ignition coil has a thermal failure. You check this by checking for spark immediately after the engine dies. If no spark I would first replace the spark plug as they can fail under compression load and try again. You still having failure then the next next to do is replace the ignition coil pack.
Dec 31, 2014 | Tecumseh Garden
1999 audi a6 hard to start but runs smooth otherwise
Check Secondary ignition first, make sure it is in good shape.
Next, cranking voltage, you need 11 volts or better.
Third, well I hope for you you don't need this one, but check all wires, connections and sensor readings to look for flaws.
4 well, if your a 20 year veteran machanic I'll explain this one.
Jan 27, 2013 | Ignition System for Audi A6
Help me with my 1993 chevy cavalier 2.2L engine. My car won't turn on when ignition switch is in the on position. When I turn it to the on position, my radio cuts on, and my air conditioner turns on,...
what do you mean by "dash lights"? how do you KNOW the pump isnt working? how do you KNOW its good? at the ignition switch the ORANGE and PINK should have power in the RUN position the BROWN and TAN/WHITE should also be HOT in the run position. There should be a red wire near the fuel pump relay, make sure its HOT when cranking. IF its HOT and the fuel pump doenst run, the pump is bad. You can also put 12V on that red wire and power the pump.
Aug 26, 2011 | 1993 Chevrolet Cavalier
Code ee22 how do you get it out of lockup
ee 22 means the heater failed to ignite in 3 consecutive tries. To reset it, unplug the heater for 30 minutes. You need to find out why the heater didn't ignite. First make sure the igniter is good. You can test it with an ohmmeter. It's resistance should be somewhere between 10 and 20 ohms. Sometimes you can tell by feeling the cover at the igniter. It may be hot. Next make sure you are getting fuel. If the fuel pump makes a loud ticking or thumping sound then you are not getting fuel to the pump. Try pressing the red reset button on the right side of the heater at the bottom to see if the float in the fuel sump is latched up. Next there is a strainer in the fuel sump you can check. Turn off the fuel at the barrel before attempting to check the strainer. If you have a filter at your oil tank you can check it too. Let me know if you need more suggestions.
Nov 20, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Carrier Gas Furnace and Hunter Thermostat not working
Definitely a furnace issue. The gas valve is not opening if you see no flame. I have seen the igniter glow but not send enough voltage to the circuit board to make the gas valve open. If this is the case you should replace the igniter. It is very fragile so please use care when replacing. Check all connections at the circuit board as well as the gas valve. Check your gas supply. Check to see if you get 24 volts AC to the gas valve. If no, replace the circuit board. If yes, replace the gas valve once you confirm that you have gas to it. If you get a pilot flame only, you will need to clean the burners and flame tray that spreads the flame from one burner to the next.
Dec 06, 2009 | Heating & Cooling
1990 Honda Civic Stall out and wont immediately restart
Disassemble and clean the carb, particularly the jets. I suspect the charge light being on is a result of your destroyed battery, which needs to be replaced. Sta-bil over the winter and a smart trickle charger will prevent the problems you are having in the future...
thank u
rate me!!
Jul 20, 2009 | 1990 Honda Civic
Laser toyostove will not ignite
Zen,
When you ran out of fuel the filter trapped some air in the very top. You need to loosen the fitting on the fuel line right at the filter and let the fuel run of a minute. This will clear the air from the top. On the way out to the filter unplug the stove. Leave it unplugged for 20 minutes. This will clear the EE22 message. Now you can restart your stove.
Tom Hawkins
hawkins111@gci.net
Apr 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
202 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
