Question about LG Televison & Video
This is the third time I have posted question. have an LG LCD 42LH30 left side has colored stripes running down the side, I am thinking T-CON board? can some one give me an answer please @ wal5ter1999
Pluged in to see what the issue was, removed the back and the LG T-Con board, the one i have is not the right one. use Jimmy shop.com but they are shut down for the month up dating their tech web site so I need some professional advice please. Thank you and God Bless. Walter.B
    Top Expert:
  • LG Master
  • 74,383 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 10, 2014
Mark_Webber
  • 472 Answers
SOURCE: LG RZ-26LZ50 LCD Television-Solid Black line down the right had side of the screen
It's the driver tabs that operate that section of the panel. To have them repaired/replaced can be very expensive and is normally just replaced completely as a whole panel (at least while under warranty). If it is out of warranty, then get a few quotes over the phone. This will help dramatically when you explain to your wife that you are about ot go shopping to buy a new TV.
I find things like "Have I told you how good you look today" help when this process is taking place.
Sorry for the bad news.
Posted on Apr 12, 2008
  • 380 Answers
SOURCE: trying to replace t-con board on a 47lg50 lcd tv,
As soon as you take the back off the set, the t-con board is located at the top middle of the set under some shielding.
Posted on Dec 08, 2009
budmrtn
  • 11361 Answers
SOURCE: I have the common "color contouring" problem (red
The T-CON board get the power from the logic board switched transistor that supplies the voltage to the T-CON board. Check to see if the 12vdc feeding the T-CON board is clean voltage and not higher than 12vdc. The problem can also be the logic board which sends the signals to the T-CON board. Does cooling the T-CON board with electronic freeze spray make the problem goes away. Some of the work I have to do is to install a small DC fan to keep the T-CON board cool and some time using heat sinks.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 27, 2010
  • 115 Answers
SOURCE: Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Posted on Jul 31, 2010
eagle338
  • 4889 Answers
SOURCE: Samsung LN52A550 - 2 1/2 years old - I have
It could either be the T-con(AKA LCD controller) or its the LCD panel. It cannot be anything else. So you should give the T-con a try and chances are it can fix the set.
Posted on Jun 28, 2011
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
What causes a Blue Vertical Stripe on left side
Can be the t con board or the lcd panel. its only possible to finalise by replacing the t con board. Before going for a new t con board try to check the connections from t con to lcd panel. if its possible remove and reconnect it. sometime bad contact can cause such problems. Also added a link which would be help full for you.
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 09, 2015 | JVC Emerald EM37T 37" 720p LED-LCD TV -...
Have an LG #42LH30 colored stripes down left side static on right
Dec 04, 2014 | LG 42LH30 42 in. LCD TV
Every day when I first turn on my LG HDTV model 42LH30 it has the left side completely black but the right side seems normal with a distinct center vertical line. After a few minutes the left side gets...
LCD TVs are side lit with either cathode tubes or LED's (depending on the model). This saves space and allows the TV's to be so thin. The newer LED TV's are backlit, so there is an array of LED behind the screen, but because your model is side lit, most likely with a cathode tube, that the tube is on it's way out and takes an excessive amount of time to warm up and get to full brightness. You culd try looking up a part number through LG, but my guess would be it's expensive and not easily replaced. Perhaps contact a local electronics store to see if they ofer repair service and see how much it costs versus buying a new tv.
Mar 02, 2011 | LG 42LG30 42 in. LCD HDTV
When my LG 42inch LCD tv is off for a while and then turned back on a broad white line is down the left hand side, if I just twist the tv round slightly it goes away and tv works perfectly till next time...
This problems it is the causes by the board that call the T-CON decoders board,this board sit at the bottom in the middle of the LCD screen panel.This T-CON decoders board is started dying to causes these problems or the fibers opotic cable connections is loses or frail damges to causes slightly signal tranmittion from the T-CON decoder board to the LCD screen panel.Just used the tv,when the problems is there for good.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Jan 27, 2011 | LG 42LC2D 42 in. LCD HDTV
LG 42LH30 THE PICTURE IS ALL BLOTCHY. THE CABLE
It sounds like you are having T-CON board problem.
http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LH30
Try cooling it with electronic freeze spray (Notes: T-CON board is under the metal cover shield).
Send me pictures if you can, budmrtn@aol.com
Jun 29, 2010 | Televison & Video
Televison & Video Logo
44 people viewed this question
Computer Repairing
Computer Repairing
