Question about Generic Akai KS 212 Top Load CDG Karaoke Machine with LED Light Effect
My akai karaoke machine has worked fine however not the disc does not turn when I select play. any suggestions
I know it has power because the lights come on. Don't know what to try
Read error
Your reader is probably going bad. You can try cleaning it with one of those home CD player cleaner kits and that might work for you.
Aug 23, 2014 | Akai Karaoke Akai KS808 CDG Karaoke System...
Disc not reading
if it\'s not reading most disc\'s then you may have to open up the machine and do a manusl clean if it\'s just the one cs then there maybe a scratch on the disc, i use either a bit of vodka or surgical
spiriton a cotton bud, "do not press on the laser" hope this help\'s, paul :)
Dec 25, 2013 | Akai KS 212 CDG Karaoke Machine with Light...
Akai ks 800 wont play cd
It is possible that the system is no good and probably should be returned or exchanged.
Dec 25, 2013 | Akai KS-800 PROFESSIONAL KARAOKE SYSTEM
My power turns on but the CD doesn't play anymore. No buttons work play, program, the screen is blue
Does it reads disc? if not it's time to replace optical mechanism, hope this helps.
Oct 26, 2013 | GPX Karaoke Party Machine
Karaoke machine
may be you need to change the DVD lens its weak
Jun 02, 2010 | Televison & Video
I have a roadstar dvd/karaoke player it wont play the cdg discs on it ,it will only play the dvd karaoke discs,is that a fault with the machine .
Sounds like yure laser is faulty or neds a clean or youre discs need cleaning try a lens cleaner most electrical shops sell them and wash and dry one of youre discs that wont play
Nov 27, 2009 | Televison & Video
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
I have a Memorex Karaoke machine, Press power button, screen comes on but it will not play a disc nor cassette. There is a small light beside the power button but it does not come on either. What could be...
Had same problem opened up back found blown fuse replaced and still blows.
Unhooked power source from were fuse was blown and fuse dose not blow seems to be something in that big board above it.I'm realy not into repairing of electronic boards. There is a lot or stuff going on inside there.
Just thought I would share my experience.
Good luck
Oct 20, 2009 | Memorex Karaoke System MKS5620RFB
MEMOREX KARAOKE MKS8503
When I press the power button, it will not work at all. It won't play a disc and the screen won't show that it is on either.
Aug 26, 2008 | Memorex Karaoke System MKS5620RFB
Generic Akai KS 212 Top Load CDG Karaoke Machine with LED Light Effect Logo
154 people viewed this question
Top Generic Audio Players & Recorders Experts
ray gallant
Are you a Generic Audio Player and Recorder Expert? Answer questions, earn points and help others
