Question about Samsung DV210AEW Sensor Dry Electric Dryer - White
My Samsung Dryer model# DV210AE does not start. I hear a quite click sound but it does not run. Control panel does work
    Problem Solver:
  • 15 Answers
Check door lock, if not faulty on/off switch
Posted on Dec 09, 2014
The gas system isnt igniting
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a kenmore dryer model 84082/04082. when i push the start button the dryer starts to spin but then i hear something click and the dryer stops and the control panel suts off then the control panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2011 | Dryers
My DV210AE dryer will not stay on unless I hold the power button in.
heatman101
Aug 18, 2011 | Samsung Dryers
I have a Samsung DV210AE Dryer that is 3 weeks old, everything works on the dryer except no heat and it is not showing any codes what do I need to do. Thanks!
The first thing to check is if you have 240 Volts going into the dryer. The display, lights, and motor run on 120 Volt but you need 240 V for the element.
May 20, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Control panel works. i am able to change all selections or settings. When I depress the start button i hear an audible click but nothing happens. No errors are showing on panel.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 27, 2010 | Dryers
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
Samsung DV210AEW Sensor Dry Electric Dryer - White Logo
300 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
