Question about Whirlpool Refrigerators
I replaced the Defrost timer and I still have to smack the area where the timer is to get the compressor to kick on and then it doesnt stay cold after the initial freeze. The freezer will defrost the
Im Looking for possibly another issue I think. I just want to not have to worry about losing food in my freezer if im gone for a few dAYS. i HAVE TO DO THIS EVERY Day.
Check out the control board behind it
i dont know the exact freezer
but probs ive found before are bad solders on the control board
where relays are
and around other connections
its behind the timer at the top????
usual place
so get out the solder iron
could also be a bad relay
its contacts platings are gone and become resistive
other than this it could be the evaporator tubes are blocked up
or the fan needs attantion {behind the freezer rear panel
lift it out check the fan clear any ice
clear and salt the water guides and drain hole./ tubes
hope this helps
have a happy crimbo
Posted on Dec 09, 2014
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
jmgldsmth
  • 1869 Answers
SOURCE: refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
Posted on May 04, 2009
SOURCE: I need to know where to find the defrost timer on
I just replace my defrost timer & defrost thermostat. The timer is in the front bottom. Remove the kick plate at the bottom & you should see an orange knob. It takes about 10 min to replace. The thermostat is located in the freezer section. Remove the lower panel. This will expose the cooling coils and the defrost thermostat. Takes about an hour to replace.
Posted on Jun 16, 2009
  • 159 Answers
SOURCE: Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Posted on Jun 17, 2009
mgprice
  • 744 Answers
SOURCE: I have a GE Profile TFX30PRYAWW defrost timer issue
Hello, This is NOT a problem with the defrost timer. This sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Aug 31, 2009
Defrost timer does not advance after defrost
During this time of defrost you manually advanced into, Did the heater turn off them self? If they did the defrost thermostat does work, if the heaters stayed on the entire time (1hr) than the thermostat needs to be replaced as well as the timer. The thermostat is a cut off device to prevent the over heating of the freezer and liner (safety device). Think of a defrost timer as an egg timer, this timer runs regardless of function just advances like a clock. The thermostat turns off the heaters when they reach a temp rather then time. I hope this answered your question, good luck
Aug 17, 2014 | Refrigerators
Model number HTR16ABSERWW
You have a bad defrost timer .
The defrost timer is a timer dial you turn to bring compressor on.
Get model and serial number of freezer/fridge and buy a new defrost timer and install and everything should be fine
Jun 01, 2017 | Hotpoint HTR16ABSR Top Freezer...
Not keeping food cold or freezing properly- have cleaned the filters - is there a drain pipe that needs to be cleaned out?
The problem you most likely are having is the defrost timer first, part number 215846602 The timer is located on bottom and behind the kick plate at base of fresh foo door. The kick plate or grill can be pulled away to expose the timer mounted on a metal bracket with a small hole in center. Try turning the timer slowly clockwise until you hear a click and compressor and fans silence. after about five minutes open freezer door and listen for a crackling or sizzle noise. That should be defrost. if the timer is worn out it may just stay where you left it. If after 25 minutes the refrigerator does not come back on the timer will need replaced. If refrigerator does come back on and begins to cool better it will be the timer. If not I wil need to explain the other two possibilities. defrost heater and defrost thermostat, Thanks, sea Breeze
Mar 10, 2010 | Frigidaire FRT22TSE
The refridgerator is not staying cold. The
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Mar 06, 2010 | Refrigerators
Compressor on sxd20tw wont shut off. just cleaned
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Refrigerators
Freezer on bottom, cold, fridge not cold,ice on
Probably the difusser door that allows cold air from the freezer into the fridge portion, either stuck or control dial faulty
Aug 22, 2009 | Refrigerators
Fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 10, 2009 | Refrigerators
Freezer Cold but not freezing
Usually this is a sign of the defrost is no taking place. On base of refrigerator behind the kick plate grill is a defrost timer. Turn the timer clockwise until compressor stops. Leave in that position for up to 30 minutes. The refrigerator should restart on its own after that wait. If not turn the timer again until compressor starts and replace timer. During the time off this should have put the refrigerator into defrost and inside the freezer compartment you should hear crackling and sizzling as the defrost heater melts the ice and water drops down onto the defrost heater. If this helps let me know. The replacement part number for the defrost timer is
215846602 If this does not help we will need to do some other test inside the freezer with the rear cover removed and power unplugged. Sea Breeze
http://servicepartstec.blogspot.com/
Jun 24, 2009 | Refrigerators
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer gets real hot
It sounds like the defrost termination t/stat (located on the freezer coil) and the defrost timer have both been jammed on by the storm. A quick way to check is to locate the defrost timer (every model seems to locate it in a different position) look for a round plastic cover around 15mm diameter inside the fridge or freezer, remove the cover and rotate the timer clockwise until you hear a firm "click" then plug the fridge into the power & see if it starts (some defrost timers can also be located near the kick plate or near the compressor well) if the compressor starts (I'm such it will) replace both of these parts.
Cheers John.
Apr 01, 2008 | Whirlpool 25.2 cu. ft. Side-by-Side...
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
