Question about Electrical Supplies
I have a predator 4000/3200 generator that worked great for a few months but now the lights flicker and go out and shuts off the power. What could be wrong?
I have checked wiring only.
3 Suggested Answers
  • 1388 Answers
SOURCE: Generator dose not produce power,just stop working.
Check the rectifier board installed under gen cover that powers the brushes. This board has a capacitor about 1 inch long and 3/4 inch dia. If the capacitor looks swollen or burned replace board or carefully remove cap and replace with similar. You can use a larger capacitor with same rating, just tie cap to rear cover. Also check the condition of the brushes. Parts are not too expensive. Check with jacksmallengines on the web for parts. enjoy
Posted on Dec 05, 2008
  • 1632 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
From where can I get an Portable power generator?
There are several available options where you can get a portable generator to avoid the inconvenience during a power cut. I was also suffering a lot as my most of the devices got expired due to the above reason. I want to get rid of all these inconveniences completely, therefore, had a predator 8750 generator review and thus selected a best one for myself. Their services are great and the inverters are light-weight and portable at the same time.
Mar 30, 2018 | Internet Computers & Internet
Predator 3200/4000 generator makes lights flicker won't run microwave adjusted carburetor worked fine turned it off started it the next day lights flickered again not enought power to run microwave.
hi
take look at the governor ( it situated very close to the carburettor with some light springs attached to it ) it an automatic throttle device which open the throttle when there more demand of electric power
Jan 11, 2018 | Electrical Supplies
How can I diagnose the problem with the indicator light flashing after supplying power for only a minute?
a problem has arisen in the converter panel /board
take it in for a proper diagnosis and repair
Apr 20, 2016 | Honda EB3000C CYCLOCONVERTER Generator -...
Dell-inspiron
it is probably a problem with your graphic card's drivers or the card itself
Apr 17, 2014 | Dell Computers & Internet
I need a battery for a predator portable generator
Go to WalMart and look at their EverStart line of batteries for motorcycles and ATV's. I have the 8750/7000 watt predator and the EverStart ES9BS works great and fits well on the holder. It comes with the acid and you will need to add the acid and fully charge the battery before use.;
Jul 27, 2012 | Electrical Supplies
Predator 500cc.i was out trail riding and it started to bog down alittle, shut it off and when i went to start it wouldnt turn over. my lights were flickering
First thing to check would be the battery connections. Make sure the positive and negative cables are tight. I've chased problems on several atvs, especially Predators, to find out the battery cables were loose. They will make the atv cut out or bog down while riding and make lights flicker. Let me know if you need anything else, Daniel.
Oct 10, 2011 | Polaris ATV
03 predator 500 electrical problem
Let the entire electrical system dry out. A warm garage would help. You might use an air compressor to help blow out any water near electric connectors etc. Then try running it again.
Oct 11, 2009 | Polaris ATV
Honda eu 6500 gen overload indicator light will not shut off
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
79 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
