Question about Buck Scrubbing Bubbles& Automatic Shower Cleaner - 2 Pack
Put new refill in unit but will not start
Tried to turn manually and not.hing happened. what am i doing wrong?
  • 56 Answers
The battery compartment contacts are probably rusted out.
I got rid of ours. We use the spray can now.
Posted on Dec 13, 2014
Limit switches on my furnace appear to be tripped ,how do I reset them?
you didnt specify unit-- generic answer --sounds like your in lock out on most units if you disconnect power to unit for a few 5+ minutes and reconnect dont try to start but reset the unit then try starting
Oct 12, 2016 | Heating & Cooling
Tip
How do I change freezer door opening side?
Hi.
Details on how to change the fridge door opening side depend on the appliance model.If this is a chest unit, you will simply need to rotate the unit. On most upright units the general procedure to change door opening orientation is more or less the one ilustrated below:
  1. Disconnect power from the appliance.
  2. Get to the top side of the unit, and remove the hinge plate. This is usually held by two Torx or Philips screws. You may need to help yourself with a putty knife to remove a protective panel covering the plate. Be careful not to damage any part.
  3. Remove top hinge and put it on one side.
  4. After removing the plate you may need to remove the plastic clip located at the top on the handle side of the door, oppositely to the old hinge side. Use the putty knife to pry up and remove the plastic clip.
  5. Open the door and lift it from the lower hinge pivot.On many fridges you will have to remove the bottom hinge too, often held by two screws, and covered with a proective pane, to free the door before removing it
  6. Carefully place the door on the floor.
  7. Remove protective panels on top and bottom on handle side of the frige cavity, reinstall the hinges on handle side position, swapping them with the protective panels.
  8. Remove the door pivot and mount it on the opposite side.
  9. On the door disassemble and refit handle or any other part if needed.
The precise and complete procedure is usually illustrated on the appliance user manual. If you need manual or schematics, try asking a new Fixya question. Ensure that you are providing full model number, as printed on service tag.
To get more detailed info you can also try calling the appliance manufacturer at the number listed on the owners manual.
Regards.
on Mar 30, 2010 | Refrigerators
My 88 plymouth reliant has just stopped working. I have changed the spark plugs, wires, fuel pump, and fuel pump relay. i've also changed the fuel filter twice now. i've checked to see if it has spark and...
Check the ignition timing is correct. I see that you have changed the wires so I suggest that you recheck the firing order for the plugs as it is easy to get it wrong when replacing the leads.
Oct 23, 2013 | 1988 Plymouth Reliant
2002 toyota hiace van front wiper reservoir refill point
I have the 1990 model and just so happened to stumble on its unusual location today as I was replacing the door hinges. On the passenger side open the door and look above the step, there should be a little plastic cap with the wiper icon on it. hope this helps!
Oct 23, 2009 | 2002 Toyota Highlander
My Beaumark Stove is from about 1964. The hinge on the oven door popped out while i was moving it. Now both hinges are out and I see no way to put them back.
there is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off .These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
This [link] http://tinyurl.com/kogjg3 should help you out.[link] http://tinyurl.com/mzgjtq is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the [link] http://tinyurl.com/mszglp just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this [link] http://tinyurl.com/lg76wg one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold the [Link] http://tinyurl.com/kren2c so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
I hope it helped.
Jun 06, 2009 | Kitchen Ranges
Pool motor keeps turning off. Runs fine in "Service" mode but as soon as I switch the controller to "Auto" mode, it starts for a second, then quickly turns off. It keeps trying over and over but then it...
Well, since this is brand new, it is still under the normal
warranty period. There must be something wrong with the controller, since it works fine in Service Mode. Just
get in touch the dealer where you buy the unit.
May 02, 2009 | A.O. Smith SQ1102 Pool Pump Motor
I accidentally got water in the oil part of the engine
Definitely DO NOT start the car...drain the oil pan, replace the plug, and refill with the proper amount of oil. Start the car and run until the engine temp is at the normal range for at least 15 minutes. Then drain the oil, change the filter, and refill with fresh oil.
Jan 22, 2009 | 2005 Pontiac Grand Prix
Windshield wiper lifts up on return path
grab hold of arm at bottom and the bend it down a bit from the top ,also try putting a drop of engine oil on the hinge at the bottom .or be like me and dont take car out in the rain.well not my jag anyway
Nov 14, 2008 | 1996 Lexus ES 300
HP 57 refill problem
You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
New refill but runs out of ink after about 8 pages
Did you stich into the ink inlet within the cart holder with a syringe for pressing some air into the tubes? Never do that! Because you have dissolve the bottom of the cart holder or drilled a hole into the bottom.
The cart holder leaks and the poured out ink has already stained the whole machine!
The bottom of the cart holder is a foil which has been sticked onto the hard plastic (clever , eh?). This also happens due to the use of  a wrong refill ink or wrong generic carts the wrong mixture dissolves the foil and ink runs out into the machine....
You need a new cart holder to fix that.
Jan 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Buck Scrubbing Bubbles& Automatic Shower Cleaner  - 2 Pack Logo
156 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
