Question about Air Tools & Compressors
How do I obtain a new trigger action for my rockworth power breaker?
    Master:
  • 755 Answers
Goto their website and to parts .
Posted on Dec 10, 2014
Breaker
What is this on? If it is a breaker, the grease is to coat the feed wires to keep the corrosion and resistance down
Apr 14, 2013 | Electrical Supplies
Rockworth 1.5 hp 6ltr oil free compressor drive belt replacement
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Feb 19, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Where can I aquire new brushes for a Rockworth 1700w breaker?
go on ebay and tap in carbon brushes match yours to the one you want i bought mine from assisi electric uk they are the best bet
HENRY
Feb 13, 2013 | Hammering
My Hobart Handler 120 stopped working during a welding process. Now when I pull the trigger, the 30a 110v circuit breaker trips. The machine can be turned on and the breaker holds (cooling fan in the...
Please don't give me a bad rating for this. Its just a little extra info. you didn't mention that may help you find the problem. Depending on your specific model, there should be 1 or 2 breakers on the unit it self. If there is only 1, it will shut down the entire machine when tripped. If there are 2, the top one is for the whole unit and the lower one is for the wire feeder motor only. There is also a thermal overload that will shut down everything except the cooling fan. Secure the trigger closed and let the fan run for a while to see if it re-starts when cooled. If the depth of the weld was stable before the problem occurred, I would suspect a short in the motor and not the rectifier. That is not a sure bet though. If the transformer does not start when it cools, UNPLUG the welder and short the transformer to ground to be sure the capacitor is discharged. Then isolate the feed motor and transformer and use an OHM meter to test them individually to ground for a short. With a little luck, it will be the feed motor. Please let me know if this helped at all. I am new and still learning how to explain what I am thinking. Thanks for writing us.
Roger
Apr 02, 2011 | Welding Tools
Bosh Brute jack hammer It does not hold chisel bits when locked in.
I have a rockworth arpd 1700 breaker and need new points and chisels any idea where i can get them from ive looked every where.
Oct 17, 2010 | Bosch 11304K Brute Breaker Hammer
Broken on/ off switch for rockworth ARPD1700 hammer drill
rockworth powertask demo hammer needs new trigger how do i get parts
May 17, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I need the parts for rockworth power task 1700w
Hello I need a new trigger switch for my Rockworth PowerTask
serial no uk004984 ARPD1/OOK. On the switch itself inside it has HY15C. Please put me in touch with your on parts division. Thanks.
Jun 13, 2009 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Rockworth 1700w Breaker - Stoppped working
I have a Rockworth Powertask which appears to have the same problem when exposing the drive gears the spline drive gear had been completely shredded together with a ball bearing race the driver gear was intact & the secondary drive gear would appear to have destroyed the drive gear - suggest repair
Mar 05, 2009 | Dewalt D25900k Heavy Duty Demolition...
Air Tools & Compressors Logo
66 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
