Question about Sharp Heavy Duty Commercial Microwave Oven R23gtf 208 / 230 Volts 1600 Watts
What is wrong when ee1 fault code appears - Sharp Heavy Duty Commercial Microwave Oven R23gtf 208 / 230 Volts 1600 Watts
  • 406 Answers
Find it here on Fixya
Error code ee1 on sharp 22at
Posted on Dec 09, 2014
Engine warning appears
You need to get the fault codes read
And stop driving before the damage gets worse
Jan 18, 2016 | Mitsubishi Montero Sport Cars & Trucks
My BMW 318i 2003 automatic transmission not responding to gear liver. what is wrong with my car?
the transmission warning light is an indication of a fault in the transmission which you apparently ignored. You were supposed to have that fault codes read immediately the light came on as that is when the repair will be at the cheapest. have the codes read now to determine what is wrong
Nov 12, 2014 | BMW 318 Cars & Trucks
Activation request for office 2011 for mac
If you do have an activation code, why not enter it in the box that appears on the screen?
Apr 14, 2013 | Microsoft Office 2011 for Mac Home and...
I would like to know the type and max ram amount that can be installed on my laptop part # av3270-ee1 it says it has 512 now so I would like to go to 1 gig. I also have some keys in operative, shift...
Welcome to Fixya. Memory Upgrade for Averatec AV3270-EE1 Laptop, the Averatec AV3270-EE1 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your Averatec AV3270-EE1 Laptop to up to a maximum of 1.0 GB Memory, the system has 1 socket to install Memory, already with 512 MB (removable) standard Memory installed.
Thanks for using Fixya.
Feb 07, 2011 | Averatec 3200 Notebook
Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
    I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • 4E/4E1
  • 5E
  • oE/9E
  • LE
  • 6E2/PE
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    Display panel shows E01 and bleeps continuous
    A model number would help, but one Sharp commercial manual lists these codes as close to what you typed:
    "EE1" Magnetron (1) failure. (could be one of many parts in the magnetron 1 circuit)
    "EE0" Fan lock judge.
    "EE10" Intake thermistor is shorted.
    FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please post a new help request with your model numbers and precise symptoms.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    May 27, 2010 | Microwave Ovens
    What causes code 1740 to appear
    there is a web site called www.bioscentral.com it show fault codes and what they mean. Fault codes never tell you exactly what is wrong with a vehicle, just the area to look in. i do believe that this is a hard drive error.
    Dec 11, 2009 | 2001 Dodge Ram 1500 Truck 2WD
    Caller ID in another language can't find manual to fix GE phone Model 29265-EE1-A
    1. Press the option button. SET 5 OR 6 appears in the display.
    2. Press the 5 (+) button until CID LANGUAGE appears in the display.
    3. Press the option button to show the current language setting. The default is English.
    4. Press the 5 (+) or 6 (-) button to change the language.
    5. Press the option button to store the language and return to the CID LANGUAGE display.
    also here's a link for the manual:
    http://www.home-electronics.net/USER-GUIDES/29265_DOM_ES_CD_IB.pdf
    Nov 08, 2009 | Lands Phones
    Error code ee1 on sharp r-22at
    EE1 on a Sharp commercial microwave is magnetron 1-related failure.
    It may be a bad connection or relay on the control board, a bad magnetron, a bad high voltage diode, etc. - anything in the high voltage circuit for the #1 magnetron.
    We have the service / repair manual for a similar model and have uploaded it to our site here to help you.
    It will give you safety info, step by step help in disassembly and troubleshooting tips, but do not rely on the part numbers shown in that manual.
    You can find part numbers and order parts from Encompass here or you can call them toll-free at 866-779-5835.
    Most computers will open the manual automatically, but you may need the free Adobe Reader
    Jun 07, 2009 | KitchenAid KHMS2050SSS Microwave Oven
    Sharp Heavy Duty Commercial Microwave Oven R23gtf 208 / 230 Volts 1600 Watts Logo
    134 people viewed this question
    Top Sharp Kitchen Ranges Experts
    William Miller
    William Miller
    Richard Lane
    Gil Shultz
    Are you a Sharp Kitchen Range Expert? Answer questions, earn points and help others
