Question about Samsung Televison & Video
I have a Samsung TV model UN46D6000SFXZA that won't turn on. I have tried a different power supply and main board with no success. Could the T-Con Bd possibly be the problem?
Posted on Dec 09, 2014
Hi there, my Samsung TV turns on, but the screen is black and the audio works. I changed the main board and power supply/LED board. I'm thinking the T-con board but I just wanted your opinion.
Maegan,
You have already changed power supply/led board and main board. What is left now is the tcon and scaler board. Please try tcon.This may solve your problem. By the way, there is a systematic way of singling out the faulty board. A little research on this will save you save you time and money. Good luck.
Jan 22, 2018 | Samsung Televison & Video
The answer to my question was to replace the T-Con Board. Looking at Shop Jimmy the only board for this model is BN44-00801E Power Supply/LED Driver Board. Is the T-Con board embedded in this board?
The T-Con board is embedded in the main board and not in the power supply/LED Driver board.
The Main board part number should be BN94-09124C but I would suggest to do more research or call Samsung for more info.
Sep 18, 2017 | Samsung Televison & Video
I replaced my t-con board in a Samsung tv model # UN46D6000SFXZA, part # BN95-00497B, with the new t-con board I'm getting sound but no picture, with the old t-con board I was getting vertical color lines...
If the LVDS cable is damaged or it hasn't been seated properly into it socket, this might happen. The absence of back light too can be the cause. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 09, 2016 | Samsung Televison & Video
Samsung LED TV (UN39FH5000FXZA) has audio, but does not have backlight. I replaced the power supply/ LED board with no success, could this be caused by the main board or the t-con board?
Hi Matt,
The fault lies with the backlight LEDs. It is common with these sets. If you open the panel and replace the failed LEDs, or replace the panei.
Good luck.
Dec 05, 2015 | Samsung 5000 Series UN39FH5000 39" LED TV...
I have a samsung lnt4066 led TV with a distorted picture. I have replaced the main board, power supply and the t con board with no success. I have pictures of what the TV is doing and would like to sh
You either have a bad t-con board or the screen is bad. Check to make sure all the ribbon cables are seated fully and connected. Even replacement parts can be bad sometimes, new and used both.
Jan 09, 2015 | Samsung LNT4069F 40 in. LCD TV
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
LN32B460B2D won't power on
There is electronic capasitors in psu that is faulty
Jan 25, 2012 | Samsung LN32B460 32 in. LCD HDTV
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Aug 12, 2009 | Samsung Televison & Video
Televison & Video Logo
160 people viewed this question
Jerry Greenberg
Jerry Greenberg
