Question about Westclox 70026A LCD Atomic Digital Alarm Clock
How do I set day and date? All else is set
Pressing mode button quickly
  • 406 Answers
SETTING THE TIME
Note:
When the signal is being received (as indicated by the atomic indicator signal)
you will not be able to make any setting or adjustments to the clock.
1. To begin setting the clock, press and hold the MODE button located on the back
of the clock for 3 seconds to enter the TIME setting mode.
2. The HOUR digits on the display will begin to flash. Press the UP or DOWN button
to set the HOUR in one hour increments. Press the UP or DOWN button as
necessary until the correct hour is displayed.
Note:
If you are in the 12 hour time format, be sure you are in the correct AM or PM
time period. When the "PM" indicator appears on the display, the time displayed is in
the 12 hour period between 12:00 noon and midnight.
3. Press the MODE button again to exit the HOUR setting and enter the MINUTE
setting mode.
4. The MINUTE digits on the display will begin to flash. Press the UP or DOWN
button to set the MINUTES in one minute increments. Press the UP or DOWN
button as necessary until the correct minute is displayed.
5. Press the MODE button again to exit the MINUTE setting and enter the
SECONDS setting mode.
6. The SECONDS digits on the display will begin to flash. Press the UP or DOWN
button to reset the SECONDS to zero.
7. Press the MODE button again to exit the time setting mode. The clock will
automatically return to the normal time display mode.
Note:
If no settings are made within 30 seconds, the clock will automatically return
to the normal time display mode. If this happens, you will need to start the time
setting procedure again from step
SETTING THE CALENDAR
1. Press the MODE button (located on the back of the clock) twice (do not hold the
mode button) to display the CALENDAR.
Note:
The YEAR icon will be shown on the display indicating you are in the year
display mode.
2. Press and hold the MODE button for 3 seconds to enter the CALENDAR setting
mode.
3. The YEAR digits on the display will begin to flash. Press the UP or DOWN button
to set the YEAR in one year increments. Press the UP or DOWN button as
necessary until the correct year is displayed.
4. Press the MODE button again to exit the YEAR setting and enter the MONTH setting
mode.
5. The MONTH digits on the display will begin to flash. Press the UP or DOWN button
to set the MONTH in one month increments. Press the UP or DOWN button as
necessary until the correct month is displayed
6. Press the MODE button again to exit the MONTH setting and enter the DATE
setting mode.
7. The DATE digits on the display will begin to flash. Intermittently pressing and
releasing the UP or DOWN button to set the DATE in day one increments. Press
the UP or DOWN button as necessary until the correct date is displayed.
Note:
The day of the week will automatically set according to the month, date, and
year.
8. Press the MODE button again to exit the calendar setting mode. The clock will
Note:
If no settings are made within 30 seconds, the clock will automatically return to
the normal time display mode. If this happens, you will need to start the calendar
setting procedure again from step 1
Posted on Dec 09, 2014
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
My timex 1440 sport watch has buttons that are slightly different than any manuel I can find on line. the buttons are as follows going clock wise from top left mode, stop/start,adjust,and indiglo. I just...
Try this:
To set time and date:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
including AM (no symbol) and PM.
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
hold button to scan values.
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
Jan 19, 2018 | Timex 1440 Nylon watch
How do you change the Date Time Stamp in the GoPro Hero series of cameras?
Taken from manual:
SETTING THE TIME AND DATE
You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is
removed the time and date settings will be lost:
Symbol on LCD Screen Function
When you see "dAt" on the screen, press SHUTTER button to set the
time and date.
Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030).
Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 01 (January) to 12 (December).
Press POWER/MODE button to toggle from d01 (1st day of month) to d31
(31st day of month). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23
(11 p.m. military time). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59
minutes). Press SHUTTER to advance to next date setting.
1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance
for the settings menu.
EXITING THE SETTINGS MENU
When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
Dec 21, 2009 | GoPro Motorsports Hero GMHW50 Digital...
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
How to set date on time clock tc 100 royal master
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time
: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Oct 13, 2008 | Computers & Internet
Date and time
CHANGE THE DATE FORMAT:(1)press the mode button on the back to select no print,year-month-day,hour- -minutes.SETTING THE DATE:(1)select date mode by pressing the mode botton.press the setting button Y,Mand D to set desired date.(2)press the mode button to access the TIME mode and adjust time by pressing the setting button H and M.
Nov 16, 2007 | Samsung Maxima 22S QD Point and Shoot...
Westclox 70026A LCD Atomic Digital Alarm Clock Logo
339 people viewed this question
Top Westclox Audio Players & Recorders Experts
pawnpower
 Grubhead
Grubhead
ka4iup
ka4iup
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
