Question about Kitchen Appliances - Others
Where can i get the bowl ? the base works fine.
Ebay
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
How do you take bowl off for cleaning
Hope you've worked it out by now, but there are 2 notches at the bottom of the bowl that slot into the base. To remove the bowl, take the lid off and rotate the bowl clockwise so the notches disengage from the base, and simply lift it off/. I assume if you couldn't do this the bowl must have had a lot of gunk stuck in the notches which prevented it from moving - yuk! I put my bowl and lid in the dishwasher - no prob.
Jul 02, 2012 | Sunbeam 4817 Oskar Food Processor
I have a kitchenaid foodprocessor 5KFPM 771 which is not working. When it's plugged in the on button will lit, but there's no turning of the blades. I reassembled it a couple of times but it's...
food processors have interlocks between the bowl, the top and the base. Inspect to see that those are all making. When you lock the bowl to the base and the top to the bowl you should hear some clicks and see some interlock mechanisms line up at the back of the bowl.
Aug 02, 2017 | KitchenAid Food Processors
I would like to purchase west Bend High performance 6500-1 part shredder/slicer blade and can't log into EBay. What can I do? I am not an Ebay subscriber.
Type in Westbend in the search bar. Several sources will return. Pick the one that interests or looks good to you and gclick it.
Oct 30, 2009 | West Bend 6526 Food Processor
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Kitchen Aid food processor, model # KFP 700 from 1970s
The closest I have seen recently - there is an auction for a complete KFP-700 with work bowl/lid intact on eBay right now:
http://cgi.ebay.com/Kitchen-Aid-12-Cup-Food-Processor-model-KFP-700_W0QQitemZ150328616612QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US
-Tha Mp3 Doctor
Mar 12, 2009 | KitchenAid Food Processors
Appears to be locked but won't turn on
Instructions only apply to Cuisinart DLC-2011 series:
Put lid on with lid lined up with work bowl handle.
Put pusher sleeve into lid's feed tube, with metal element facing the front of the food processor.
-Tha Mp3 Doctor
Apr 16, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Odc325
I haven't been able to find the base heating element for sale anymore. Best I can suggest is finding one on ebay that still has a working base heater but the water heater no longer works.
Oct 26, 2007 | Black & Decker SpaceMaker ODC325 Coffee...
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Kitchen Appliances - Others Logo
74 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
