Question about Garden
I have a 1990 trailboss 4x4 polaris i put new rings and pistons in it started for a minute then quit its getting fire what could be wrong
  • 26 Answers
Everything could be wrong, wrong size piston, rings, but most likely you have a timing issue. since it ran at first and I don't know how well or long it could have jumped time or broken the tensioner for the chain. but if it was slightly off you probably bent a valve an it is staying open slightly preventing compression. pull out your plug and put your finger over the plug hole to check the compression. if no compression then you bent the valve.
Posted on Dec 09, 2014
Testimonial: "now it just back fires how do you time them"
  • monty murphy
    monty murphy Dec 09, 2014
    its got compression
SOURCE: 1990 polaris trailboss , trans ,or clutch slips in water
Check for wore clutch belt and also check to see if your getting water in the clutch housing. If your getting water in the housing, your clutches could be corroded as well. There should be no water getting in that shroud.
Posted on May 19, 2009
  • 9 Answers
SOURCE: polaris will not run
Seriously, guydaigle? The 300 Xpress is a two stroke. The problem is too much fuel. Start by checking and adjusting the carb. Look at the needle & seat, then the float level.
Posted on Nov 09, 2009
lindsay836
  • 677 Answers
SOURCE: I have a 1999 Polaris Diesel 4x4. It will run for
I would say you may either have water in your fuel or a filter that should be replaced, or even a blocked air filter.
Please let me know what you find
Posted on Feb 07, 2010
Testimonial: "At least you've given me a starting point. I'll let you know what I find out. Thank you for your help."
SOURCE: Instructions to tighten the chain on a 2003 Polaris Trailboss 330
I have the same problem and it's wearing on my frame we tightened it and all it did was stiffen the suspension
Posted on Jun 10, 2011
  • 32 Answers
SOURCE: i put a stator in my 2007 polaris 330 trailboss and it still want charge
Gap setting could be incorrect, the the battery could be bad. Stator only put out a couple of amps just enough to maintain a good battery.
Posted on Nov 15, 2012
93 polaris trailboss 350l 4x4 new piston and rings ....no suction at carb
This is not enough info to start. ..Hold the palm of your hand over the back of the carb and make sure its sealed against it... You need a helper to do this properly. The engine should pull on your hand inwards... if not....??
Did a shop or factory trained mechanic do the work? Are the reed valves able to open and stay closed? What does the compression gauge read? If you don't have one, beg borrow, buy, and/or take it to a shop and pay them to check it. Check it with the throttle wide open... with new piston and rings it should pump over 120+psi. ..easily.
Have the compression checked and then repost with the results.
Thanks!
May 28, 2017 | ATVs
How do you remove the thermostat from a 93 Polaris trail boss 350L 4x4
DOWNLOAD POLARIS TRAIL BOSS REPAIR MANUAL
trailboss-manual.blogspot.com/
Nov 5, 2014 - 4x4 free printable 1989 polaris trail boss 350 2x4 parts 03 polaris 350trail ... engine diagram trail boss 350 4 stroke diagram how to test the thermostat ... apolaris trail boss 1994 350 shop manual for 1993 polaris 4x4 trail boss ... boss 350oil pump repair manual for polaris trail boss 1987 removing jets in ...
Sep 25, 2015 | ATVs
I put new piston and rings in my polaris 1990 trailboss it started for a min and died whats wrong
was it literly a minute that it ran or was it like 10-15 minutes with you reving it up a bit? It could be many different things from as simple as it ran out of the gas that was in the carb and the tank valve is shut off to things like your magneto coil is shorted, no spark. Have you checked for spark and fuel? Does the engine have compression? More details will help solve your problem.
Brian
Dec 09, 2014 | Polaris ATV
How to pull off sleeve strut seal on a polaris
Some struts are sealed and cant be repaired. others have a large nut on the top can be removed with a special tool.
Oct 20, 2014 | Garden
Mypolaris300expresssmokesandenginegetsveryhotdoesntseemtobegettingenoughoil
what kind of oil do you put in it?im not sure but i think for your type of 4 wheeler you use 10w-40 or 20w-50,if the oil you put in is too thin it will over heat,as for the smoking it could be the rings or it could be valve stem seals letting a little oil drip by,but you wouldnt have very much smoke if it was the valve stem seals my guess is rings and if it is your atv will be losing power sometime soon if you keep riding it and will eventually quit running,then you will need a new piston and rings,i could be wrong,im just now getting into atv repair...........hope it helps
Aug 24, 2010 | Polaris ATV
1987 polaris trailboss piston
Sure - it is worth fixing when a new one is 2300
Mar 31, 2010 | RTO 200cc Full Size Four Wheeler ATV
Feb 07, 2010 | Polaris ATV
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris will not run
Aug 22, 2009 | Polaris ATV
May 18, 2009 | Polaris ATV
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
