Question about Samsung Computers & Internet
How difficult is it to replace a wifi module in a Samsung PN51E800 plasma tv. The unit won't DHCP with my wireless router
  • 35 Answers
Why not save the money and just set it static??
Posted on Dec 16, 2014
5 Suggested Answers
  • 56 Answers
SOURCE: Router doesn't obtain WAN IP address (DHCP)
you can hook the router up and go into the settings by when it is hooked up to your computer, type in http://192.168.0.1 and the password is usually user or admin. the password is usually password, unless it was changed. you may be able to change settings to fix this problem through that GUI
Posted on Jan 06, 2008
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
govinda123
  • 2263 Answers
SOURCE: Laptops cannot connect via WiFi through Belkin
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Jan 15, 2010
  • 451 Answers
SOURCE: my wifi light won't turn on and i have no wireless connection
you need to configure the wireless settings
connect to your router using a cable and then go to your browser to 192.168.1.1
go to wireless and setup your wireless network settings
Posted on Feb 27, 2012
When I run the wireless setup on my Samsung PN518000 plasma tv it times out and does not obtain the necessary IP information. Does the community feel replacing the wifi module in the TV will fix this...
did you check out the menu setting for wifi setting first
then check too see if there is something mode wise isnt right
i would setup a hot spot on your phone and try that
if it connects to the phone and not too your wifi
then atleast you can rule out the TV
cant seem to find too much info on this unit
Dec 09, 2014 | Samsung Televison & Video
I m unable to connect wifi for my samsung 65 led tv
Does the TV have WiFi enabled? Is it in range of your WiFi router? Is the place where the TV is located a WiFi dead spot? Does the TV see your WiFi router, and is it the strongest signal in the TV's locality? Are your neighbours using the same WiFi channel as you? Have you got the router set to block MAC addresses? Is the TV set to use DHCP? Is the router handing out IP addresses? What security level are you using? Are you putting in the correct WiFi password? The list goes on and on.....
Sep 06, 2014 | Samsung Televison & Video
I need a pass through wifi router
The best soultion is to install a hub or a network switch.
If your wireless router has LAN ports then connect your computer with a LAN cable to the wireless router.
Feb 07, 2013 | Computers & Internet
How do i enable DHCP on my router
The problem most likely is not the router problem since the router use DHCP as default setting.
Oct 25, 2012 | Zyxel Prestige 660HW Wireless Router...
My samsung touch wifi is hanged
Try setting up a static IP and see if that works. If that works, then at least you know you have DHCP problems, which are mostly likely on the server itself (your router, etc.). If the static IP works, then go to whatever your DHCP server is and look for an option to clear all previously remembered leases. Then go back and start fresh again by re-enabling DHCP on the phone or did not solved Try restarting your router..Had similar issues with Linksys. Then delete and recreate your Wireless profile on your phone.i hope it is helpful to you thanks
Jun 28, 2011 | Cell Phones
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
May 18, 2011 | Computers & Internet
I purchased the lg an-wf100 dongle. It connects to my wifi but is asking for a manual ip entry. I have a 42lg5500 led tv. The manual/automatic field is frayed out, so is the DNS field.
Sounds like your router isn't set for DHCP. Try entering an IP address that isn't in use on your network. You'll find the IP address range in your routers settings. Either that, or set your router to DHCP. Hope this helps.
Regards,
Matt
Mar 16, 2011 | LG ANWF100 Wireless dongle
My Samsung TV connects to the internet when I plug it directly into my D-Link DSL modem. But when I run it through a Linksys WRT54G router (using a wired connection) the TV can't "see" the internet. I've...
have you tryed bridge mode on the modem
which device is doing the routing dhcp only one can do the dhcp
is the internet light lit on the router, the router is set for ppoe for dsl
try turning off dchp on the router let the modem handle
Jul 06, 2017 | Linksys Wireless-G WRT54G Router
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
3com 3CRWER200-75 wireless router won´t connect to certain sites
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
Nov 03, 2008 | 3Com OfficeConnect Wireless Router
Computers & Internet Logo
51 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
